299
[DO NOT USE] [GUI]OnePlus One Toolkit by manudroid19
Thread Status:
Not open for further replies.
  1. manudroid19
    Honeycomb Sep 18, 2014
    manudroid19 , Sep 18, 2014 :
    click root and follow steps, they are clear
    maybe, i will think on it.
    rom flashing in v2.3 more less
    no it doesnt, but why would someone like to do that?
    yes it does
    is a bug, please wait for next version, will be out in a few days...
    dlackey and Yemasa like this.
  2. Elaerha
    Froyo Sep 18, 2014
    Elaerha , Sep 18, 2014 :
    I really think this is going to come in handy for a lot of people out there that don't know much about tinkering your phone. Great work!
  3. Rajatbosch
  4. .crobin
    Honeycomb Sep 28, 2014
    .crobin , Sep 28, 2014 :
    Hello manudroid, thanks for awesome work.
    Is it possible to root and install TWRP without dataloss?
    Can I simple use root and it will root without loosing data?
    best regards
    Jgarciaillanf1 likes this.
  5. nikku_hot123
    nikku_hot123 , Sep 28, 2014 :
    i have lost my network and wifi. i did a backup of efs.img earlier but now even after restoring network is not coming. On restoring following messege is coming .Please help me :(
  6. Jgarciaillanf1
    Gingerbread Sep 28, 2014
    Jgarciaillanf1 , Sep 28, 2014 :
    The 2nd mode to unlock the bootloader...
    When is going to be stable?
    I wish i can unlock the bootloader without loss data...it would be perfect...
    :D:D:D
    Edit: When that method will be operative in 33R and the next OTA's? If there is possible...
    Thanks @manudroid19
    Adugr8 likes this.
  7. Adugr8
    Jelly Bean Sep 28, 2014
    Adugr8 , Sep 28, 2014 :
    Chrome, virustotal and mcafee say the file contains malware... So I can't install it....
  8. .crobin
    Adugr8 likes this.
  9. manichon
    Gingerbread Oct 4, 2014
    manichon , Oct 4, 2014 :
    Would yoy please add an option to change language, I'm on a spanish only pc, but I want to be able to read everything in english.
    Also, the "gestionar drivers" section says to touch some buttons which just aren't there...
  10. Adugr8
    Jelly Bean Oct 4, 2014
    Adugr8 , Oct 4, 2014 :
    @manudroid19 Could you please look into this. I can't install it due to this. Very nice work on the program though.
  11. selumoreno94
    Gingerbread Oct 5, 2014
    selumoreno94 , Oct 5, 2014 :
    Hola buenas, habeer voy ha hacer la copia del EFS pero he tenido que formatear el ordenador hoy y entonces tengo que instalar los drivers de nuevo ¬¬
    Estoy utilizando el Toolkit de @@manudroid19 Y los pasos a seguir son sencillos pero al llegar al penultimo y al ultimo me surgen problemas.. ya que Al instalar los drivers de Samsung siguiendo todos los pasos, se me queda en la segunda opcion que se queda como que no lo reconoce (A001) y segun las instrucciones hay que clicar en "Configuracion final" pero lo hago y tampoco responde, no sale nada y no veo que el programa reaccione y muestre algo
    PD: Al intentar hacer el Backup del EFS se me queda esperando el CMD y no hace nada..
    Si alguien sabe como solucionar estas dos cositas se lo agradeceria :D
  12. Jgarciaillanf1
    Gingerbread Oct 7, 2014
  13. manudroid19
    Honeycomb Oct 7, 2014
  14. Jgarciaillanf1
    Jgarciaillanf1 , Oct 7, 2014 :
    Gracias, no tenía claro que por llamarte Manu tuvieras que ser español, mucho mejor así :D:D:D
    Ojalá los consigas con la nueva versión y la 38R contribuya a ello...
    Gracias de nuevo :):):)
  15. Nuklid
    Eclair Oct 7, 2014
  16. Adugr8
    Jelly Bean Oct 9, 2014
    Adugr8 , Oct 9, 2014 :
    Everything on my computer says its malware too...:(
    ash23 likes this.
  17. manudroid19
    Honeycomb Oct 9, 2014
    manudroid19 , Oct 9, 2014 :
    v2.0 is up!!!
    Link: https://www.mediafire.com/?ljkoi4jfz7jj2pi
    Changelog:
    -Added ADB & Fastboot devices list on main menu
    -Now toolkit check devices connection before doing anything
    -Now toolkit checks if bootloader is unlocked (if needed)
    -Added Italian translation
    -Added French translation
    -Added German translation
    -Fixed bug while opening "Final Configuration"
    -Updated recovery and kernel links
    -Fixed EFS Backup!
    Jack_Carver, agtws and mikeniccy like this.
  18. Jack_Carver
    Froyo Oct 10, 2014
    Jack_Carver , Oct 10, 2014 :
    Great work, I love seeing the project advance! :)
    Though one suggestion for 2.1, could you add expandability?
    manudroid19 likes this.
  19. g.cuadrado
    Ice Cream Sandwich Oct 10, 2014
    g.cuadrado , Oct 10, 2014 :
    Hola manu, es recomendable el método de desbloqueo del bootloader sin hacer wipe? O quizá pueda ser problemático?
  20. manudroid19
    Honeycomb Oct 10, 2014
    manudroid19 , Oct 10, 2014 :
    si tienes 25r, no hay ningun problema...
