3
Does anyone faces oneplus buds side not working issue?? via OnePlus 8 Pro
  1. #1
  2. KOMALKUK
    Cupcake Sep 2, 2020
    Rajab Pasha likes this.
  3. K1599880374850
    Cupcake Sep 12, 2020
    R1582458140909 likes this.
  4. R1582458140909
    Cupcake Sep 14, 2020
  5. pashazz
    Gingerbread Sep 14, 2020
    pashazz , Sep 14, 2020 :
    Same issue from Day 1. Failed product in every way. You have been cheated.
  6. sureshselvaraj , via OnePlus 8 Pro , Sep 24, 2020 :
    [Fix on my side] Few days ago, I bought the buds from the oneplus store and noticed one side not working but the staff told me to insert into the ears properly, like pressing the buds towards the ear, then after 2 seconds it was working.
    Try pressing the buds towards the ears while you are wearing it.
  7. Pratyaksh Rao
    Donut Sep 26, 2020
    Pratyaksh Rao , Sep 26, 2020 :
    Same issue with my ear buds.
    my left one is completely dead, it's showing 0% battery all the time.
    I looked for the solution and found that you need to update the firmware so i did that and its 340.309 but i don't think that's the latest firmware.
    JelleZon likes this.
  8. Pratyaksh Rao
    Donut Sep 26, 2020
    B
    tried everything bro, but the left earbud shows 0% battery and there's no sound coming out of it
  9. Ananthan13
    Cupcake Oct 6, 2020
    Ananthan13 , via OnePlus 7T , Oct 6, 2020 :
    bro iam also facing same issue do u get any solution for this
    Pratyaksh Rao likes this.
  10. #10
  11. Ananthan13
    Cupcake Oct 6, 2020
  12. #12
  13. #13
  14. Ananthan13
    Cupcake Oct 6, 2020
    i tried everything bro its only 2 days since i bought it....i dont know what to do..
  15. #15
  16. Ananthan13
    Cupcake Oct 6, 2020
  17. #17
  18. Ananthan13
    Cupcake Oct 6, 2020
  19. #19
  20. sureshselvaraj , via OnePlus 8 Pro , Oct 12, 2020 :
    Try, to make a phone call while connecting with buds. Since , media sound and call audio are handled differently, you can check it by this method. If u hear on both sides while you are on call but one side only while on playing songs, then a sensor might be problem or u might not have properly inserted the buds in the ear. If that doesn't work, kindly take it to the service store.
