Does anyone have any ways to make earphones louder?
  1. brian2012
    Froyo Apr 22, 2015
    brian2012 , Apr 22, 2015 :
    Just push them in your ears more. But seriously, I'm sure there's an app for that.
  2. erzengelsachiel
    KitKat Apr 22, 2015
    erzengelsachiel , Apr 22, 2015 :
    An active preamp is not something an app will ever be able to achieve. This is an example of a quality active preamp:
    DarkVoice 336SE Headphone Tube Amplifier
    http://www.amazon.com/gp/product/B0...N=B00CF9JON8&linkCode=shr&tag=shopfaster0c-20
    Here's a cheaper one for the audiophile on a budget:
    Bravo Audio V2 Class A 12AU7 Tube Multi-Hybrid Headphone Amplifier
    http://www.amazon.com/Bravo-Audio-V...m_sbs_e_2?ie=UTF8&refRID=0FZVTR8R2ESHJE8KJYKP
    These will boost your dB and add warmth to the mix.
    eromore189 likes this.
  3. vinnyJager
    Donut Apr 22, 2015
    vinnyJager , Apr 22, 2015 :
    Very whise, my one is broken now :/
  4. 0mnomnom
    Jelly Bean Apr 22, 2015
    0mnomnom , Apr 22, 2015 :
    What music player do you use on your OPO? If it's not the stock player, some have built in EQ/preamp and volume control settings.
  5. FrederikOlsen
    Ice Cream Sandwich Apr 22, 2015
    FrederikOlsen , Apr 22, 2015 :
    you are a lucky fellar indeed.
  6. fgaurano
    fgaurano , Apr 22, 2015 :
    Yes, there are two files in there, for Gingerbread and 4.x and above, choose the 4.x
  7. eromore189
    Gingerbread Apr 22, 2015
    eromore189 , Apr 22, 2015 :
    I use the play music app. Same as you?
  8. zzjgmzz
    Froyo Apr 22, 2015
    zzjgmzz , Apr 22, 2015 :
    The impedance of your earphones are not matched to your opo's output.You will never be able to have a nice clean signal.If you put some kind of booster software, it will be louder but distorted.
    You can use a external preamp like the FIOO E06 .You will get a loud and clean signal.
  9. Tobikage
    General Support Expert Award 2021 Apr 22, 2015
    Tobikage , Apr 22, 2015 :
    This ^^
    If you want real volume boost , nothing else will work..
    erzengelsachiel likes this.
  10. 0mnomnom
    I use Power Amp. It has a few settings that work differently on different phones. Not sure about the built in app. Maybe it's that AudioFX thing on OPO? Do you have it enabled?
  11. NickSalonika
  12. eromore189
    I tried it with both the AudioFX enabled and disabled. Same result.
  13. 0mnomnom
    Longshot maybe, but try rebooting after enabling/disabling audioFX. Mine messed up a couple times and would get stuck on or off and only a reboot would fix it.
  14. menacho.eulogio
    Lollipop Apr 22, 2015
    menacho.eulogio , Apr 22, 2015 :
    Mine does the same thing!!
    sidlittlefield likes this.
  15. Tyronekramsey
    Tyronekramsey , Apr 22, 2015 :
    Franco kernel. If you have fku updater app you can make it higher
  16. forid-786
    forid-786 , Apr 22, 2015 :
    No need to use this bogus apps, there's a xml file. Can't remember the name now, you can change the actual values in there if you're rooted. And I've experienced this too with some headphones, some just seem to require extra power.
  17. Lingering
    Lingering , Apr 22, 2015 :
    Preamps are hardware not software.
  18. gringoboy
    gringoboy , Apr 22, 2015 :
    Invite only.
    #38
  19. FrederikOlsen
    blast! I expected such an obstacle would occur. Well i might as well bucker up and prepare for ensuing invite tussle.
    #39
  20. theshinybeast
    Marshmallow Apr 22, 2015
    theshinybeast , Apr 22, 2015 :
    Don´t be so cruel with the poor chap I had exactly the same problem until I saw this
    #40
    eromore189 and sidlittlefield like this.
