Does anyone know a fix for this problem?
  1. G1514788366119
    Cupcake Jul 23, 2020
    G1514788366119 , Jul 23, 2020 :
    There red n green blurry vertical lines on the right side of screen from top to bottom. is there a fix for this?
  2. Katrick
    Ice Cream Sandwich Jul 23, 2020
  3. Karthik_Mounika
    Honeycomb Jul 24, 2020
  4. G1514788366119
    Cupcake Jul 24, 2020
    G1514788366119 , Jul 24, 2020 :
    yes spontaneous, it was working fine the whole week then suddenly today this happened.
  5. Karthik_Mounika
    Karthik_Mounika , Jul 24, 2020 :
    That's a serious issue with screen then, dead pixels and it's permanent...only solution is screen replacement..
    But if it's spontaneous, seriously poor quality control of OnePlus to be blamed... pathetic
  6. Cosmos_NT , via OnePlus 7T Frosted Silver , Jul 24, 2020 :
    No, unfortunately there's no fix for that. It is hardware damage - the lines are permanent. You need a screen replacement.
    It happens when the screen or the frame gets a hard hit by fall or maybe extreme pressure. But if that suddenly happened, then it could be a factory defect but can't be said without opening the device.
  7. N1594214027064
