Does anyone know of the upcoming "Warp charger 30T" is compatible or work with the oneplus 7 pro?
  1. trailrunner76
    Eclair Sep 22, 2019
    trailrunner76 , Sep 22, 2019 :
    Does anyone know of the upcoming "Warp charger 30T" that is made for the upcoming Oneplus 7T pro, compatible or with with the oneplus 7 pro?
    I have the op7 pro and was thinking of getting upcoming "warp charger 30T" (23% faster) and wondered if I would get the same performance, or does that 23% performance increase only applicable for the oneplus 7T pro?
    Thanks,
    trailrunner76
  2. Moin2200
    KitKat Sep 22, 2019
    Moin2200 , Sep 22, 2019 :
    I'm pretty sure it's the same as warp charge.
    There is no difference. It's the same charger.
    Nothing to do but to wait for official event and see.
    trailrunner76 likes this.
  3. jboucher614
    Eclair Sep 23, 2019
    jboucher614 , Sep 23, 2019 :
    The 30 likely means it's still 30W, so it should charge the OnePlus 7 Pro the same speed (in theory). If it's faster for the 7T Pro they must be doing something special such as having it at full power for longer amounts of time. I'd stick with standard Warp 30 unless you want to future-proof it. But this is all just a guess
  4. trailrunner76
    Eclair Sep 23, 2019
    trailrunner76 , Sep 23, 2019 :
    Thanks. Interesting that Oneplus can manipulate the newer phone (7T Pro) to be able to draw quicker and more electricity from the same charger.
  5. Deactivated User
    Sep 24, 2019
  6. S1563712850755
    Cupcake May 9, 2021
  7. Arjun_Choudhry
    KitKat May 9, 2021
    Arjun_Choudhry , May 9, 2021 :
    You can use the warp charge to charge a OnePlus 7. It won't cause any damage, but it will charge at normal Dash charge speeds
