does applying back panel screen protector affect wireless charging via OnePlus 8 Pro
  1. I1594383813378 , via OnePlus 8 Pro , Oct 22, 2020 :
    Hello everyone.
    does applying back panel screen protector affect wireless charging . Please reply and help me.
    I brought the wrap wireless charger and it takes more than 2 hours to charge. When I visited the service center they told me it's because of the screen protector applied on the back please help me guys.
  2. Viraj Pnvs
    Gingerbread Oct 22, 2020
  3. I1594383813378 , via OnePlus 8 Pro , Oct 22, 2020 :
    No I did not peel it off. th cost of it is 599rs. But I just wanted to know does screen protector affect wireless charging when I went to service center to complain slow charging they gave me this screen protector reason
  4. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 22, 2020 :
    Everything that moves the phone further away from the charger slows it down. How thick is it? If it's very thin it should not affect much.
    Liehjan and Tokolozi like this.
  5. I1594383813378 , via OnePlus 8 Pro , Oct 23, 2020 :
    It's a matte screen protector its not that thick.
  6. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 23, 2020 :
    Then it should not affect much. What is your temperatures when charging? (including ambiant temp).
    You can for example check charge current with Ampere.
    https://play.google.com/store/apps/details?id=com.gombosdev.ampere
    There you notice the effect on good vs bad placement on the charger (angle matters).
    https://play.google.com/store/apps/details?id=flar2.devcheck
  7. I1594383813378 , via OnePlus 8 Pro , Oct 23, 2020 :
    Can you help me with ampere app I have installed but what to check . And how to know whether I'm getting 30watt wrap wireless charging or no. What should be the number to check
  8. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 23, 2020 :
    When discharging you see negative values. The middle one is the current charge/discharge. Left is min and right is max speed. Big drain also leads to slower charge speed of 2 reasons. The discharge speed and temperature being higher.
    Depending on battery temperature you could get max speed at 0-30% or something. The higher you go it steps down in current both due to charge level and temperature control. Max should in optimal situations be above 5.5A. 6A is the theoretical max (P=U•I, 30W=5V•6A). On cable I have maxed at about 5.8A. I always charge with a case on and regardless of bedtime mode or not I get far from max speed. Without case it is around 30% faster or so. Compare orginal Sandstone on/off. But my current case is slightly thicker (and should be slower).
    Wireless is also more sensitive to heat due to energy losses. So wireless charging could require slightly colder ambiant temperature to compete with cable charging.
    SoumitraLimaye and luigimario like this.
  9. I1594383813378 , via OnePlus 8 Pro , Oct 23, 2020 :
    Hello this is when I'm charging without case on wireless charger
    Is it okay??
  10. #10
  11. I1594383813378 , via OnePlus 8 Pro , Oct 23, 2020 :
    Is my wireless charger proper then ? Can you help me please. I'm confused.
  12. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 23, 2020 :
    At 80% battery level your 2.5A is normal. It goes even lower the closer to 100% you get. You get higher current at lower battery level. Just like when charging with cable.
    Check the speed at approx 15% battery level and you will see faster speeds.
    As far as I can see so far it looks normal.
    When you do a full charge and it feels slow you might want to check the temperature. Temperature could be the cause of it to slow down. That is normal too.
  13. I1594383813378 , via OnePlus 8 Pro , Oct 23, 2020 :
    So my charger is normal. No need to visit service center right ??
  14. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 23, 2020 :
    Without knowing exactly how it behaves at 15% or e v en lower... No. Looks normal from what I can see.
    If a full charge heat up the phone the speed will be lower and depending on the ambiant temperature and the heat your SoC produces.
    Check your charge speeds at a low battery level. If that too looks normal a slow charge might be as simple as heat limited.
  15. I1594383813378 , via OnePlus 8 Pro , Oct 23, 2020 :
    How much should it be when battery is low. Can you explain with an image please as it will explain me better. Was worried but thanks to you
  16. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 23, 2020 :
    A simplified sample... I drew a line that symbolises charge speed. The first section is max charge speed. Then the higher it goes it steps down.
    This is however also controlled by temperature and not just the charge level.
  17. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 23, 2020 :
    Theoretically you should pass 5A+ depending on how low you go. 5.5A+ perhaps
  18. I1594383813378 , via OnePlus 8 Pro , Oct 23, 2020 :
    Thank you so much. As soon as the battery goes down will charge and send you screenshot so that you can help me find out. Wether my charger is fine or no
  19. #19
  20. #20
