does CN ONEPUS9PRO WORK WITH.US.TMOBILE 5G via OnePlus 9 Pro
  1. G_Leon_Shao_mGca
    Cupcake May 29, 2021
  2. Caomhin
    OnePlus 9 Series Expert Community Expert May 29, 2021
    Kruemelfelix and Aaron2017 like this.
  3. MomZo
    Honeycomb May 29, 2021
    MomZo , May 29, 2021 :
    I read there is a problem or wrong/missing anchor which makes 5G not working even with the same supported NR bands.
    Caoimhín likes this.
  4. Caomhin
    Caomhin , via OnePlus 9 Pro , May 29, 2021 :
    It's possible. Until someone tries a Chinese model in the US it will be hard to know. And US carriers don't like unlocked phones on their networks so that's another factor.
  5. McLarenMania
    McLarenMania , via OnePlus 7T Pro 5G , May 29, 2021 :
    I wanted the OnePlus 6 avenger edition so bad that I ended up buying a Chinese version from eBay. I assume you want to use a Chinese OP in the US rather than just travelling with a CN version
    My learnings :
    You have to install all Google apps yourself.
    I could not change to global ROM from Chinese ROM without flashing. Chinese ROM luckily supported English but that's about it. No other European or Latin American languages
    Some third party apps couldn't be uninstalled.
    Google Maps started acting up after couple of months. All photos taken would display a location in China for some reason
    Most obvious is the need to buy a charging adapter
    Certain 5G bands not supported due to carrier limitations. Flashing to global ROM doesn't work either
  6. MomZo
    You can ALWAYS flash the global version on a Chinese OnePlus variant.
    Except for my OnePlus One that I bought in France, me previous 5 and 6T came from China where I did a lot of business trips before, and I always flashed Oxygen OS Global version right out of the box. No problem.
    My 9 Pro is also from China and I am currently running Oxygen OS India (DA) (installed by my reseller)
  7. Swejuggalo
  8. MomZo
    Yes, but there is a tutorial on XDA to get 5G back in that case. This is also working for OnePlus phones that "should" receive the 5G but which don't.
    Downside is you lose the workaround when you reboot your phone or install an update...
  9. G_Leon_Shao_mGca
    G_Leon_Shao_mGca , via OnePlus 9 Pro , May 29, 2021 :
    Yes, I agree checking on LTE. It's easier, but ones come to the 5 G, then. It is a different situation,
    I actually really want to try out the color os. So so far I have not seen any link showing 。us version flash。color os。
    anyone have luck for this ?
  10. G_Leon_Shao_mGca
    flash india version of oxygen? maybe like globe VERSION ?
    then we can flash color OS ?
    do I lost my US model 5g?
    please advise
  11. Swejuggalo
    Swejuggalo , via OnePlus 9 Pro Stellar Black , May 29, 2021 :
    I misunderstood what you intended to do so I removed my comment. But not fast enough apparently 😉
    If I find something put I'll let you know.
  12. Swejuggalo
  13. McLarenMania
    Honeycomb May 30, 2021
