Does One plus one supports HDMI ? Could we connect it to TV using HDMI cable ?
  1. aris
    Jelly Bean Mar 27, 2015
    aris , Mar 27, 2015 :
    Can you connect the OnePlus One via OTG cable to a smart TV Usb port?
    #61
  2. dkulkis
    Froyo Jul 10, 2015
    dkulkis , Jul 10, 2015 :
    Yeah, actually it is, because who wants to tether their phone to their TV...that's rather idiotic
    #62
  3. agazza
    Honeycomb Jul 13, 2015
    agazza , Jul 13, 2015 :
    When you want a pocket console and want to use a controller to play games.
    but yeah, try to play with screencast. The latency will probably not be a problem for you.
    #63
  4. NepalR_
    #64
  5. slylenser
    Eclair Sep 17, 2015
    slylenser , Sep 17, 2015 :
    I want to connect the OP2 to a HDMI LCD projector, if I get a USB-C to HDMI convertor / cable, will that work with a projector?
    b. Does anyone have an apple USB-C to VGA convertor? Will that allow the OP2 to connect to a projector?
    #65
  6. naveendennis
    Cupcake Oct 10, 2015
    naveendennis , Oct 10, 2015 :
    It's helpful when you need to watch offline videos on your TV from your phone
    #66
    cyblackledge likes this.
  7. saminpgh
    KitKat Oct 11, 2015
    saminpgh , Oct 11, 2015 :
    Hmm thats fair.
    #67
  8. DomagojKuvezdic
    Cupcake Nov 12, 2015
    #68
  9. PaulF8080
    Gingerbread Nov 15, 2015
    PaulF8080 , Nov 15, 2015 :
    I plugged my my MHL to HDMI adapter into the phone and got nothing. It worked my Samsung Galaxy Note and all of the phones listed here:
    http://www.mhlconsortium.org/devices.aspx
    "Why would you do that?" Ask the owners of these many other phones. For me, I bought the adapter and used it very little.
    #69
  10. petesouthan
    Cupcake Jan 1, 2016
    petesouthan , Jan 1, 2016 :
    Chromecast is an independent device it Does NOT do the same job as a simple cable connection. It is totally reliant on having a good WiFi connection. I live on a boat, well off the grid with no WiFi and only the occasional mobile signal. Chromecast is no use at all!! Not even for ballast!! When you operate in more challenging parts of the world you begin to appreciate simplicity and reliability and built in redundancy. (If one system fails, you always have another) useful to remember guys we are not all geeky city dweller's.. A HDMI connection would make this device nearly perfect for my needs.
    #70
    cyblackledge, script and puccellino like this.
  11. Deactivated User
    Jan 1, 2016
    #71
  12. DrJMun
    KitKat Jan 1, 2016
    DrJMun , Jan 1, 2016 :
    Chromecast would be so much more convenient. Completely wireless so no need to be physically tethered to the TV.
    #72
  13. aakashjhaveri
    Lollipop Jan 1, 2016
    #73
  14. joguirian
    Gingerbread Mar 14, 2016
    joguirian , Mar 14, 2016 :
    Is it possible to connect the OPO to tv with hdmi? I would like to try some new software and i need a way to conect to the tv.
    What is the best buy of an OBD2 scart (bluetooth) for my car (audi diesel 2003)
    Many thanks...
    #74
  15. noquarter
    Lollipop Mar 14, 2016
    noquarter , Mar 14, 2016 :
    Hi
    Thread created in the French subforum. Moved and merged
    #75
  16. Deactivated User
    Mar 14, 2016
    #76
  17. Sc0rpi0
    Cupcake Apr 1, 2017
    Sc0rpi0 , Apr 1, 2017 :
    No, most phones doesn't support HDMI Out(YET), but you can connect your phone to your pc/laptop, and then HDMI connect your pc and tv. But as mentioned from many users here both Miracast and Cromecast / Airplay is the future, but I find Cromecast the best, Cromecast require Android/IOS and a local Wifi signal, whereas Miracast supports any wifi compatible items / connections (it makes its own Wifi connection, so it doesn't need a local signal) And Miracast is very power hungry and your phone MUST stay awake while streaming. You can DL apps for both to setup/control them from your PC. iOS/Mac requirer their own solution which is Airplay.
    #77
  18. Atilla1860
    Eclair Apr 8, 2017
    Atilla1860 , Apr 8, 2017 :
    The problem with. Chromecast is you can't connect to hotel wifi. So in lieu of a cable now you have to carry a chromecast and a router. I'd rather have MHL.
    #78
  19. michaeloneil
    Cupcake Jan 23, 2018
    #79
  20. klonisp
    klonisp , Jan 23, 2018 :
    I thing Chromecast you get the job done. It is a cheap solution. Google it.
    #80
