Does OnePlus 7 have Volte and WiFi calling?
  1. Mentonian© Cupcake May 22, 2019
    Mentonian©, May 22, 2019 :
    I have really enjoyed these features on my 6t and I am helping my wife with her new 7 pro. There are no Volte or WiFi calling icons like on the 6t. Does it just run in the background?
  2. the_o2 Marshmallow May 22, 2019
    the_o2, May 22, 2019 :
    Yes it has,
    Just check the screenshot this thread
    https://forums.oneplus.com/threads/notification-bar-issue.1037184/
    You should check the SIM and network settings for that or
    inside the display settings-> status bar-> icon manager, enable the voWiFi/volte icons.
  3. Mentonian© Cupcake May 22, 2019
    the_o2
    Yes it has,
    inside the display settings-> status bar-> icon manager, enable the voWiFi/volte icons.​
    Thanks for the screenshot. That reassures me that the function does exist. We have already enabled Wi Fi calling in the SIM settings(no Volte option), but it seems to do nothing and the icons are not even available in icon manager, like they are on my 6t. My 6t is unlocked and her 7 Pro is the T Mobile variant. I am wandering if that is the difference.
  4. the_o2 Marshmallow May 22, 2019
    That might be the reason,
    I will check and told you if any forum member using T-Mobile 7Pro...
    Mentonian© likes this.
  5. Ultraman215 Gingerbread Jun 17, 2019
    Ultraman215, Jun 17, 2019 :
    Does anyone know how to enable and or disable WiFi Calling on the unlocked OP7PRO ?
    It appears to be enabled on my phone with no way to disable...
  6. F1560805295188 Cupcake Jun 17, 2019
  7. the_o2 Marshmallow Jun 18, 2019
    the_o2, Jun 18, 2019 :
    Yep, because the the guy who posted that thread deleted it.
  8. F1560805295188 Cupcake Jun 18, 2019
    F1560805295188, Jun 18, 2019 :
    I saw other guide and I tried the *#800# menu, but there is nothing where it supposed to be.
  9. the_o2 Marshmallow Jun 18, 2019
