Does OnePlus 8T have Horizon Light?
Does OnePlus 8T have Horizon Light Notification?
  1. YES
    56.3%
  2. NO
    43.8%
  1. champi 123
    Donut Oct 23, 2020
    champi 123 , Oct 23, 2020 :
    Yes, maybe was more usefull If It blinks constantly with the screen off to show there is a notificación pending.....not only 2 seconds....
    Struggled to see there isn't a solution atm for the lack of nottify LED.
  2. Swejuggalo
    Community Bug Hunter Oct 23, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 23, 2020 :
    Yes it needs to repete somehow... But in a smart way. Just a waste of battery if it blinks like crazy during the night or while in your pocket over and over again when you can't see it anyway.
  3. dionisdei
    Gingerbread Oct 23, 2020
    dionisdei , Oct 23, 2020 :
    Guys! The 8T totally has Horizon Lights for notifications, and it works perfectly. Sure, maybe the effect is not the same as on a curved display, but the feature is there in the settings
  4. melbigmike
    Donut Oct 31, 2020
  5. Arvind_Aarav
    Froyo Oct 31, 2020
    Arvind_Aarav , via OnePlus 8T , Oct 31, 2020 :
    No, I guess. I used to have Realme X before 8T which also has similar option , but it works fine on flat display well. Why would OnePlus include the option settings but won't work on mobile?
  6. SultanaDaaku
    Honeycomb Oct 31, 2020
  7. rohithk169
    Eclair Oct 31, 2020
  8. Bittoo06
    Ice Cream Sandwich Oct 31, 2020
  9. Swejuggalo
    Community Bug Hunter Oct 31, 2020
    Bittoo06 likes this.
  10. X1603141720046
    Gingerbread Oct 31, 2020
    X1603141720046 , Oct 31, 2020 :
    It's useless...it has been useless since the first time they implemented it. Even if you can get it to work...it will only flash ONE TIME upon receiving a notification. So if you're not looking directly at your screen when it flashes you will miss it...WHAT'S THE POINT ONEPLUS???????? Make it adjustable or just remove it! How stupid can developers be?
  11. Bittoo06
    Ice Cream Sandwich Nov 1, 2020
    Bittoo06 , Nov 1, 2020 :
    Woah! That's OP for you! Suprise!
  12. ShreyasPatil_
  13. faizan_ahmad xyz
    Gingerbread Nov 1, 2020
  14. faizan_ahmad xyz
    faizan_ahmad xyz , Nov 1, 2020 :
    No it has. Working fine on OnePlus 8 T
    McElectric likes this.
  15. faizan_ahmad xyz
    Gingerbread Nov 2, 2020
  16. Chris_sandi
    Froyo Nov 23, 2020
    Chris_sandi , via OnePlus 8T , Nov 23, 2020 :
    Can you explain how? I've set it on mine and it does nothing. Is it only certain types of notification? All that happens for me is my lockscreen shows with the notifications. In the video above, there is no locksceen shown.
    faizan_ahmad xyz likes this.
  17. faizan_ahmad xyz
    Gingerbread Nov 24, 2020
    faizan_ahmad xyz , via OnePlus 8T , Nov 24, 2020 :
    #38
  18. ANIX JOJU SEBASTIAN
    #39
  19. #40
