Does the color balance setting actually work for you?
Does the color balance setting work on your device?
  1. Yes, I can see a difference in color temperatue.
    31.7%
  2. No, I don't see any change.
    68.3%
  1. jiia
    Cupcake Dec 28, 2015
    jiia , Dec 28, 2015 :
    I have a keen eye for color balance and I can honestly say the color balance setting does nothing at all on my device. It's especially easy to notice now that the new quick setting slider lets you preview the screen while changing the value. I found a thread about this on XDA and everyone agreed that the slider does nothing on their devices too.
    I'm curious if you guys are seeing any difference? Or maybe the effect is so subtle it's impossible to notice?
  2. wmm
    KitKat Dec 28, 2015
    wmm , Dec 28, 2015 :
    When it works, it's definitely more yellow at the right end and bluer at the left end on my phone, at least. It doesn't always work, though; it appears that it only works once per session, requiring a reboot to work again.
    nitin_g3 and Chopzzay like this.
  3. EG12
    Honeycomb Dec 28, 2015
  4. zehar.salem
    Honeycomb Dec 29, 2015
    zehar.salem , Dec 29, 2015 :
    Good point ... never tried it before as the balance was good.
    Now that I tried it and it makes no difference at all !!!
    Another bug to fix ;) the dev team have some work to do here
  5. varunsood
    Froyo Dec 29, 2015
    IvanMuse likes this.
  6. antoniolio
    Froyo Jan 13, 2016
    antoniolio , Jan 13, 2016 :
    On my device doesn't works. I can't see anything different moving the sliding bar...
  7. manedark
    Gingerbread Jan 13, 2016
    manedark , Jan 13, 2016 :
    Works for me though you have to be on a white background like this forums background to notice it. I like to keep it all the way to blue side.
  8. MafiaTechTeam
    Jelly Bean Jan 13, 2016
    MafiaTechTeam , Jan 13, 2016 :
    I can see a very slight difference
    IvanMuse and anupritaisno1 like this.
  9. pratyush1993
    Gingerbread Jan 23, 2016
    Skie626 likes this.
  10. anupritaisno1
    KitKat Jan 24, 2016
    anupritaisno1 , Jan 24, 2016 :
    It works
    You're just not noticing it as the effect is too subtle
    You need to be on a white background and full brightness in a dark place to be able to see a difference
    nitin_g3 likes this.
  11. Chopzzay
    Cupcake Jan 24, 2016
    Chopzzay , Jan 24, 2016 :
    ^ This. It does the same to me, works on boot but doesn't work after you used it once. Hopefuly it'll be fixed on next update
  12. Methiri
    Ice Cream Sandwich Jan 24, 2016
    Methiri , Jan 24, 2016 :
    Does nothing for me. Tested on white screen etc like people are suggesting here. Zero difference.
  13. ThePixelCutter
    Gingerbread Jan 24, 2016
    ThePixelCutter , Jan 24, 2016 :
    faint, do it on a multicolour screen, with oranges and reds, i can see it but its very minute change
  14. Jitesh Saitawadekar
    KitKat Jan 25, 2016
  15. Ivanpoocky13
    KitKat Jan 25, 2016
    Ivanpoocky13 , Jan 25, 2016 :
    It works for me, can see the difference between bluish and yellowish colors as I play with the slider
  16. mayursawant
    Ice Cream Sandwich Jan 25, 2016
    mayursawant , Jan 25, 2016 :
    those who can't see the difference you people might be blue-yellow colorblind! trust me.
  17. Notch_1608
    Honeycomb Jan 25, 2016
    Notch_1608 , Jan 25, 2016 :
    It works perfectly for me. The extreme left end of the slider is to turn the display a bit cooler (blue), whereas the extreme right end of the slider is to turn the display a bit warmer (yellow). Try wiping Dalvik cache and cache, and if possible, dirty-flashing OxygenOS 2.2.0 and see if it works.
  18. aakashjhaveri
    Lollipop Jan 25, 2016
  19. gamsurslick
  20. alexferdean
    Ice Cream Sandwich Jan 26, 2016
