Does the OnePlus 7 pro work with DASH chargers?
  1. Maor Shabi
    Cupcake May 18, 2019
    Maor Shabi , May 18, 2019 :
    hey , I've got the OnePlus 3T with the DASH charger and im thinking about switching to the OnePlus 7 pro, but the thing is that in my country the carriers for some reason take the dash charger out of the box and if you want it you need to buy it separately (like i did..).
    I've been heard that the WARP charge is just a new name to the DASH charge (cause of copyrights or something) and it brings me to my question- will my dash charger that I know for sure supports the 6T , work with the new OnePlus 7 pro?
    thank you for your answers
    Krogoth2k likes this.
  2. camohan
    Nougat Moderator May 18, 2019
    camohan , May 18, 2019 :
    Dash charger will with work with OP7 pro, but it will charge at dash charge only and not at warp charge. Dash charge works at 20W and wrap at 30W. You need the right adaptor, wires are interchangeable.
    DanielP1977 and Bouncer71 like this.
  3. Maor Shabi
    thanks, and you mean that the WARP charger need to be a bit faster than the DASH charge according to OnePlus and the fact it runs at 30v, right?
  4. Moin2200
    KitKat May 18, 2019
    Moin2200 , May 18, 2019 :
    Yes warp charges at 30v and dash charges at 20v.
    So you’ll loose a bit of speed but it’ll still be fast.
    Bouncer71 likes this.
  5. camohan
    Yes Warp charge > Dash charge and all it takes it the right adaptor. To be honest, practically it won't make much of a difference as dash charge is equally fast.
    Bouncer71 and Dirk66 like this.
  6. Maor Shabi
    yeah DASH charge is already super fast and I've seen that there isn't much of a different or even not at all in between the DASH charge and the WARP charger.
  7. Shield10
    Honeycomb May 18, 2019
    Shield10 , May 18, 2019 :
    It's 30 watt (volt × Ampere = Watt)
    ( Power = Potential Difference × Current )
  8. stansuys
    Gingerbread May 18, 2019
    stansuys , May 18, 2019 :
    it will work on the power of the dash charger but the warp charger is 50% faster
    Loper_fan likes this.
  9. jerrymilton
    Jelly Bean May 18, 2019
  10. JerrySuize
    Froyo May 18, 2019
    JerrySuize , May 18, 2019 :
    If you use Dash charge instead of Warp charge, the charging speed will get slower.
  11. irasivley93
    irasivley93 , May 18, 2019 :
    If you charge the phone during a regular scenario it isn't going to matter how fast it charges. I charge my phone at night mostly while sleeping so what do I care if it charges quickly or not. I think either charger would be okay for topping phone off for quick trips out of the house if necessary.
    prd068 likes this.
  12. OnePlusBigFan
    Cupcake May 24, 2019
    OnePlusBigFan , May 24, 2019 :
    I have bought OnePlus 7 Pro and tried to charge it using already owned OnePlus Dash Car Charger and Dash Charger Cable. The result is that I am not getting Dash Charge speed of charging. The highest power output is at 1700 mA, Dash Charge is double that.
    Is the Dash Car Charger NOT able to charge at expected speed when used with OnePlus 7 Pro?
    Shery4life and Jeb277 like this.
  13. chaitanyakorde
    Eclair May 24, 2019
    chaitanyakorde , May 24, 2019 :
    Yes, it does. I've been using my OnePlus 3 Dash Charger to charge my 7Pro.
    It charges at 20W but its considerably faster as the difference between 20W and 30W is just 10 minutes for 0 to 60% charge, which IMHO is negligible.
    alexferdean and prd068 like this.
  14. xakep
    Gingerbread May 26, 2019
    xakep , May 26, 2019 :
    I am actually getting same result as kotolows. I have OnePlus 6 Dash car charger and it also does NOT charge at dash Speeds.
    Question, do you know when you plug it in and it's showing special icon on the top right and it's telling you that it's charging at DASH speed. People who saying that it works did you actually SEE message that it's dash and special icon ?
    Also I'll use my USB voltage meter and get you a photo of what do I have. Also just FYI my OnePlus 6 using same cable and same charge does work and charging at DASH Speeds. So as of right now My OnePlus 7 Pro in the cash is getting "generic" power even using Dash hardware from previous phone and it SUCKS !
  15. Hoots2
    Gingerbread May 27, 2019
    Hoots2 , May 27, 2019 :
    I seen your post earlier today and figured I would give it the test since I have both chargers, first is my disclaimer.
    My results are mine and mine only. Your results may, and/or be different. I claim nothing but my test for information purposes.
    I started with Dash charging block and Warp charging block. I used same cable on both tests that came with the 7 pro. I used the same electrical socket. I used my 6T countdown clock set at 30 minutes.
    Test #1 7pro shutdown started at 15%. At the end of 30 minutes, I booted up and had 61%. This was with the Dash charging block.
    Test #2 same 7 pro started at 15%. End of 30 minutes, I booted up and had 62%. This is with the Warp charger.
    My opinion, the claim of 30% better is a boat load of Huey.
    According to AccuBatteryPro, the 6T claims to have a 3700 m/a battery design. They claim estimated capacity is 3552 m/a.
    7 Pro has 4000 m/a battery design, estimated capacity is 3656 m/a. This is why my 7 Pro dies just as quick as the 6T. My 5T lasts longer than both of these with 3000 m/a estimated capacity.
    I hope this helps. Let the haters pile on!
    redvw likes this.
  16. Hoots2
    Totally false
  17. Hoots2
    Go to the play store and download AccubatteryPro, its free. You will see in milliamps exactly what both chargers are doing.
    Dash charging block will go to 3300 to 3500 m/a at first, but within 30 seconds it drops back to 1000 to 1200 m/a.
    Warp charger will go to 5100 to 5200 m/a for 15 to 20 seconds, then drops back to 1000 to 1200. In essense its the same charger that performs identical. Nothing more than a gimmick for sales.
    I did a real time test and posted the results, check it out....
    redvw likes this.
  18. stansuys
    stansuys , May 27, 2019 :
    but the warp charger can deliver more powr if you are using youre phone it will load its battery at the same speed so you can charge and game without having to think willi have enough battery when i leave and i tested because i have the both chargers to and it charges a bit faster with the warp brick
  19. Krogoth2k
    Eclair Jun 4, 2019
    nikolay5556 likes this.
  20. Kash76
    Cupcake Jun 7, 2019
