Does the OnePlus 7 pro work with DASH chargers?
  1. Kash76
    Cupcake Jun 9, 2019
  2. Krogoth2k
    Eclair Jun 9, 2019
    Krogoth2k , Jun 9, 2019 :
    One more thing. 150cm flat dash charge cable says "Warp Charge" when connected but it instantly drops to ~2000ma. Changing to 100cm warp cable instantly works as 5000ma+
  3. veignt
    Cupcake Jun 9, 2019
    veignt , Jun 9, 2019 :
    i try to using my car dash charge for my oneplus 7 pro. i can see theres blue sign on the ambient display. but sometimes the blue sign gone n the charge speed getting slow. when the blue sign appear its charge very fast. i wonder whats the problem that make the blue sign turn on n off
  4. Menahjatwa
    Eclair Jun 12, 2019
    Menahjatwa , Jun 12, 2019 :
    I am using the dash adapter and cable at the office and i am also only getting 12xxmA. Pretty sure this is a hardware problem with the first batch of the phone, i don't have the warp charge right now but will charge it later when i get home and monitor how much Amp i'll get with that.
  5. Kash76
    Cupcake Jun 21, 2019
  6. AdamHinds
    Eclair Jul 11, 2019
    AdamHinds , Jul 11, 2019 :
    I too have Dash car charger and when connect to 7pro do not get Dash charge. This is annoying as now have to look at purchasing new accessories. Annoying!
  7. _udayraj_
    Froyo Jul 12, 2019
    _udayraj_ , Jul 12, 2019 :
    Dude, the thing you're saying is about OP7. OnePlus 7 Pro does charges fast with warp charge unlike OP7 charges with same speed on both the charger. Get your facts right.
  8. camohan
    Marshmallow Moderator Jul 12, 2019
    camohan , Jul 12, 2019 :
    Thanks but please read again my comment. The question is whether 7 pro will work with dash charger.
  9. _udayraj_
    Froyo Jul 12, 2019
    Then I think you need to improve your typing skill. Just read what you have typed.
  10. camohan
    Thank you for your suggestion. I will do the needful.
  11. KillerKisame
    Eclair Aug 9, 2019
    KillerKisame , Aug 9, 2019 :
    So if I have a dash charger (adapter & cable) from one plus 6 it will charge 20 w dash charge on one plus 7 pro? No battery depreciation or damaging the battery on one plus 7 pro?
  12. Matt 80
    Lollipop Aug 9, 2019
    Matt 80 , Aug 9, 2019 :
    Yes.
    All batteries depreciate over time, but it won't cause any abnormal depreciation or damage.
    noquarter and dsmonteiro like this.
  13. ceejaycee
    Gingerbread Aug 10, 2019
    ceejaycee , Aug 10, 2019 :
    Yes and no. When connected to a DASH charger, the display will read 'charging rapidly'.
    (this is faster than using a generic USB-C charger, but not as fast as WARP charging.) Hope that clarifies things a bit.
  14. Menahjatwa
    Eclair Aug 14, 2019
  15. OutlawCecil
    Cupcake Oct 9, 2019
    OutlawCecil , Oct 9, 2019 :
    -A N S W E R-
    I have a Oppo-branded DASH car charger that always DASH charged my 3T without any issues. My OnePlus 7 Pro does not DASH charge using it!
    I just did a live chat with OnePlus support and was told "Your OnePlus 7 Pro will only fast charge with the supported chargers. You need a Warp Car Charger to charge your OnePlus 7 Pro". I asked him to confirm DASH chargers will not DASH charge a 7 Pro and he replied: "Since there needs to be a circuit match between the device and the charger, you will have to use the Warp Car Charger to charger your device at Warp speeds."
  16. Dullyhood
    Cupcake Dec 9, 2019
    Dullyhood , Dec 9, 2019 :
    So the cable that I am using doesn't matter? It can be a cable from an older one plus charger but as long as it's with the right adapter?
  17. camohan
    Marshmallow Moderator Dec 9, 2019
    camohan , Dec 9, 2019 :
    Yes thats right.
