DOL-HDR issue on OnePlus 9 pro via OnePlus 6
  1. SaiKalyan999
    Eclair Jul 15, 2021
    SaiKalyan999 , via OnePlus 6 , Jul 15, 2021 :
    While watching HDR videos on Netflix, YouTube, Amazon prime etc the blanks are not shown as blacks instead they have light grey tint. Please fix this it as it's spoiling the visual experience from an oled panel during night times.
  2. drl431
    Junior Moderator, Community Hero 2020 Junior Moderator Jul 15, 2021
    drl431 , via OnePlus 6 , Jul 15, 2021 :
    Hi, you can submit a bug report to OnePlus via the feedback forum. Or if using the community app, tap the red + button and select feedback.
    Caomhin, the_o2 and J4t1np4r3kh like this.
  3. Nipu_1998
    The Lab Reviewer - OnePlus Nord 2 Jul 16, 2021
    Nipu_1998 , via OnePlus 9 Pro , Jul 16, 2021 :
    Hi there,
    Did you try changing the colour profile settings? said:
    also, DOL-HDR is not something related to the HDR playback of the device, its something related to the camera hardware.
    DOL-HDR: Digital Overlap High Dynamic Range
    In the DOL-HDR technology, an image processing technology for subjects with high contrast. It synthesizes different exposure conditions into an image so that both bright and dark data can be seen at the same time.
  4. SaiKalyan999
    Eclair Jul 19, 2021
    SaiKalyan999 , via OnePlus 9 Pro , Jul 19, 2021 :
    I see, thank you for letting me know about DOL-HDR. And yeah I have tried changing the color settings and it has been the same
  5. Midhun_k
    Cupcake Oct 27, 2021
    Midhun_k , via OnePlus 9 Pro , Oct 27, 2021 :
    Hey are you still facing the issue is it a hardware issue ?
  6. SaiKalyan999
    Eclair Oct 27, 2021
  7. Midhun_k
    Cupcake Oct 28, 2021
    Midhun_k , via OnePlus 9 Pro , Oct 28, 2021 :
    Is it a hardware issue? Should I replace my current op . Is it just us facing this issue? Also while locking screen from lockscreen shows a green popup tint for a sec in dark room can you check yours if you face this issue this issue can be seen only when fingure print is enabled
  8. SaiKalyan999
    Eclair Oct 28, 2021
    SaiKalyan999 , via OnePlus 9 Pro , Oct 28, 2021 :
    It's totally software thing but this is there only on her content for me, and though it's a software bug I have no hopes for them to fix this, cause I heard this is also there on OnePlus 8 pro.
  9. SaiKalyan999
    Eclair Oct 28, 2021
    For me this is the last op product I use, I always like their clean UI which was close to stock Android compared to Android skins or there. Now this merge with oppo everything is changing. Oxygen os isn't oxygen os anymore that I love. If I had known the company was taking this turn I would have waited and maybe bought pixel 6 pro
  10. Midhun_k
    Haa yea op lost their mind my last phone was op 7 pro it's hard to see that there are more bugs in 9 pro
    I thought I ll never buy a op phone after green tint issue on my op 7 pro but the alert silder and the oxygen OS bring me back here
  11. Midhun_k
    I thought it's a hardware issue and there are lot of bug the screen is messed up instead of showing black it shows grey Im totally irritated by this
  12. SaiKalyan999
    Eclair Oct 28, 2021
    It's most likely a software bug if you are thinking it's a software bug, just download a dark gray photo and check at all brightness levels. That should show you whether you have a green tint or not
    Midhun_k likes this.
  13. Midhun_k
    Cupcake Nov 22, 2021
    Midhun_k , via OnePlus 9 Pro , Nov 22, 2021 :
    Thanks, nope it's only visible while watching videos
