don not showing 5Ghz band wifi on oneplus 6T
  1. ShehaburRahman
    Cupcake Mar 7, 2019
    A1542130361076 likes this.
  2. drl431
    Community Hero 2020 Mar 7, 2019
    drl431 , Mar 7, 2019 :
    You can try resetting: Settings > System > Reset options > Reset Wi-Fi, mobile & Bluetooth.
  3. ShehaburRahman
    Cupcake Mar 7, 2019
    ShehaburRahman , Mar 7, 2019 :
    that doesn't work
  4. drl431
    Which os version are you using?
  5. ShehaburRahman
    Cupcake Mar 7, 2019
    drl431
    Which os version are you using?​
    latest . oxygen os 9.0.12
    my friend using 5ghz with his iphone ,but not showing on my OnePlus 6T
  6. drl431
    Have you restarted your phone recently?
  7. ShehaburRahman
    Cupcake Mar 7, 2019
  8. drl431
    You can file a bug report directly to OnePlus via the feedback forum.
  9. ShehaburRahman
    Cupcake Mar 7, 2019
    maybe it's not a bug.i got two update but still same.
  10. drl431
    Maybe not. For what its worth, I can see 2 different neighbors 5 ghz networks, with an OP6 on 9.0.4
  11. ShehaburRahman
    Cupcake Mar 7, 2019
    then what's the problem my friend can use with his iphone 8 . but not showing any 5G band on ******* OnePlus 6T
  12. Blue-agila
    Ice Cream Sandwich Mar 7, 2019
    Blue-agila , Mar 7, 2019 :
    Im assuming that your friend can see 5G on the same nerwork that you can not
  13. ShehaburRahman
    Cupcake Mar 7, 2019
    same network,same router , and i can use with my macbook
  14. lummujaj
    Eclair Mar 7, 2019
    lummujaj , Mar 7, 2019 :
    try to change the chanel of you 5ghz in router ... ive set mine to chanel 36. know your phone before you buy it .
    and dont you know about a site called Google ?
  15. ShehaburRahman
    Cupcake Mar 7, 2019
    first see what the hell are you talking about
  16. lummujaj
    Eclair Mar 7, 2019
    go to your wifi router settings and change chanel of your 5ghz ...
  17. ShehaburRahman
    Cupcake Mar 7, 2019
    check my previous comment
  18. steffen
    Eclair Apr 4, 2019
    steffen , Apr 4, 2019 :
    My 5t needed me to change ssid for 5ghz net to be different from 2.4ghz net, then login manually first time
  19. Sighn
    Gingerbread Apr 4, 2019
    Sighn , Apr 4, 2019 :
    Sure the router SSID for the 5GHz network isn't set to hidden?
