Don't have double tap setting for 7pro 5g for OnePlus buds via OnePlus Community App
  1. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Sep 25, 2020
  2. #3
  3. Liehjan
    Liehjan , Sep 25, 2020 :
    Do you know of you have the global or the China version of the buds?
    Artemus. likes this.
  4. #5
  5. Electw
    Eclair Oct 13, 2020
  6. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Oct 13, 2020
    Liehjan , Oct 13, 2020 :
    Try to factory reset the buds and set them up again, also check that you have newest version of buds app.
  7. Electw
    Eclair Oct 13, 2020
    Electw , via OnePlus Community App , Oct 13, 2020 :
    I already did a factory reset, nothing. I am also unable to get the buds app as it is "incompatible" with my device.
  8. peterbm462
    Donut May 18, 2021
    peterbm462 , via OnePlus 7 Pro 5G , May 18, 2021 :
    Mine too don't have that option. The reason behind is that this sprint 5g version has modified oxygen os. Which is why your buds is not getting all the menus/options in the Bluetooth section. Try using "hey melody" apps from the playstore (I'm using).
