2
Double and Single Tap via OnePlus 7T
  1. SimonChong0711
    Cupcake Apr 23, 2021
    SimonChong0711 , via OnePlus 7T , Apr 23, 2021 :
    The double and single tap to wake up screen features always dont work in beta 4, I really cannot stand with it, it happened in beta 2, solved in beta 3, and in beta 4 it comes back, it is really a bad experience, really really bad
    aymusbond and @iamsandy like this.
  2. @iamsandy
    Gingerbread Apr 23, 2021
    SimonChong0711 likes this.
  3. SimonChong0711
  4. Sam197
    Ice Cream Sandwich Apr 24, 2021
    Sam197 , Apr 24, 2021 :
    Go to apps
    OnePlus launcher
    Clear the cache
    Clear the data,but you have to set up everything after that
    Hope that works for you
    Edit
    May be uninstall updates
    Restart your phone to recovery
    Clear the cache
  5. @iamsandy
    Gingerbread Apr 24, 2021
    @iamsandy , via OnePlus 7T , Apr 24, 2021 :
    Will this work??
  6. Tausif.Shaikh786
    Froyo Apr 24, 2021
  7. Sam197
  8. @iamsandy
    Gingerbread May 4, 2021 at 4:29 PM
    @iamsandy , via OnePlus 7T , May 4, 2021 at 4:29 PM :
    Go to settings>battery>battery optimization>ambient display>select don't optimize...after doing this double tap to wake is working fine for me so far..
