Double Tap not working
  1. LMeneses31
    Cupcake Dec 27, 2017
    LMeneses31 , Dec 27, 2017 :
    hi everyone,
    I'm having issues when waking up screen using double tap. Sometimes it takes more than 6 double taps for screen to light up. Is anyone having the same issue?
    Br,
    Meneses.
  2. armannicky
    LMeneses31 likes this.
  3. allisterr
    Honeycomb Dec 27, 2017
    allisterr , Dec 27, 2017 :
    I don't have a problem on mine. It works fine. Do you have a screen protector on your phone? Perhaps the screen protector is causing an issue with the touch sensitivity?
    Do you notice any other touch sensitivity problems or is it only with the double tap to wake up?
  4. allisterr
    Strange, what version is your operating system? Maybe we have different updates for the different regions then. (hopefully these would be ironed out in the future update as you mentioned).
  5. LMeneses31
    I hope that it gets fixed.
  6. Mahammad94
    Ice Cream Sandwich Dec 27, 2017
    Mahammad94 , Dec 27, 2017 :
    Yeah, when I first brought the phone this happened, what I did to resolve it was to unlock with fingerprint, then try double tapping, works flawlessly, after couple of minutes double tap doesn't work
  7. LMeneses31
    I am running oxygen 4.7.4.
  8. allisterr
    Me too. Wonder what's the difference. Mine works every time. Strange!
  9. LMeneses31
    Im having the same problem. After a while it gets annoying :(
  10. sakthi15
    sakthi15 , Dec 27, 2017 :
    it's working on my mobile... go and change settings....
    I too having issues with do not disturb mode it's not working....
  11. LMeneses31
    hi, i have the screen protector that came with the phone. the sensitivity is good. the only problem is the double tap function [e]1f61e[/e]
  12. tk519
    tk519 , Dec 27, 2017 :
    Yeah I also felt sometimes it does not work the first time and works if you try again.
  13. G_David_Robins_jLMA
    Cupcake May 31, 2018
  14. gjones9038
    gjones9038 , May 31, 2018 :
    if you're using a launcher other than the OnePlus launcher, double taking won't work.
    I installed the pixel launcher and double tap stopped working, but does work if I switch back to OnePlus launcher.
  15. G_David_Robins_jLMA
    G_David_Robins_jLMA , May 31, 2018 :
    I'm not, I just received my 6 yesterday and it updated oxygen OS and now it's not responding every time. sometimes it works other times it takes several tries.
