3
Double tap problem
  1. domoimasu
    Cupcake Dec 12, 2014
  2. thechosin44
    KitKat Dec 12, 2014
    thechosin44 , Dec 12, 2014 :
    didn't know how to make it work, saw this thread, found an answer that worked for me
    double tap on the status bar...
    thanks
  3. Jazz365
    Honeycomb Dec 12, 2014
    Jazz365 , Dec 12, 2014 :
    You need to uncheck custom lock screen.
  4. ManojjonaM
    Gingerbread Dec 13, 2014
    ManojjonaM , Dec 13, 2014 :
    Even I face the issue of having to double tap multiple times :(
    I have enabled the option in the settings, not sure what else need to be done.
    I'm on 44S
  5. marcyeo
    Ice Cream Sandwich Dec 13, 2014
    marcyeo , Dec 13, 2014 :
    Mine worked great ;) but it was turned off after I updated to 38r though
    ronoldo likes this.
  6. ronoldo
    KitKat Dec 13, 2014
    ronoldo , Dec 13, 2014 :
    Haven't had that problem, but sometimes have to tap again... I think most of the time it's my fault... I have had no issues really
  7. vishal7412
    Cupcake Dec 14, 2014
  8. ramsabi
    Jelly Bean Dec 14, 2014
    ramsabi , Dec 14, 2014 :
    That is how it is supposed to work. You have to double tap on the status bar in the normal screen
    Double tapping anywhere to sleep is on the lock screen. If you use a pin/password, you have to double tap in the input field.
    To enable the feature for the lock screen, you have to turn of custom lock screen.
  9. vishal7412
    vishal7412 , Dec 14, 2014 :
    Done the same but still only go to sleep when touch on the upper middle part.
  10. ramsabi
    Yes buddy. Read my post above.
  11. corchea
    corchea , Dec 14, 2014 :
    double tap to sleep works better if you tap in the upper right corner of the phone, just on the hour.... to awake, tap on lower part....
  12. ewijn
    ewijn , Dec 14, 2014 :
    I tried to buy the one plus one but the site mentioned that I don't have an invite.
    In various articles on the internet is mentionned that untill christmas an invite is not needed to order.
  13. Jazz365
    Honeycomb Dec 14, 2014
    Jazz365 , Dec 14, 2014 :
    After unchecking it did you notice a different lockscreen?
  14. vishal7412
    did not understand
  15. vishal7412
    yes It is changed now but double tap to sleep only working when touch in the top
  16. Richbking
    Froyo Dec 14, 2014
    Richbking , Dec 14, 2014 :
    I really like this setup. Thanks!
  17. Jazz365
    Strange. For me the phone sleeps when I double tap lower half of the lockscreen.
  18. sixstringer83
    Froyo Dec 15, 2014
    sixstringer83 , Dec 15, 2014 :
    I'm on 44S and the double tap to wake works about 60% of the time. Sometimes it takes 3 attempts. It seems the screen or perhaps the software needs a you to double tap in a very specific way. Frustrating, to say the least. Hopefully, they're still working to improve this.
    Does anyone know if there's a 'feature request' page through OnePlus or do I have to go through CyanogenMod?
  19. lindat
    Froyo Dec 17, 2014
    lindat , Dec 17, 2014 :
    No lock screen....should I try with lock screen?
  20. diogo.f
    Gingerbread Dec 17, 2014
