12
Double-tap screen to unlock not really working after update.
  1. wallflowerface
    Eclair Jun 7, 2016
    wallflowerface , Jun 7, 2016 :
    Hey,
    Although the update made my phone WAY faster, my double-tap to unlock the screen doesn't work 80% of the time. I have the "home" button set to double-tap to lock. I also have a case but I keep my phone open on my desk and just go back and forth from double-tapping the screen to the button.
    Does anybody have any ideas on what to do to fix this? It's really annoying to have to keep picking up my phone to unlock it either with the side button or by flipping my case back and forth....
  2. amomtaz
    Donut Jun 7, 2016
    amomtaz , Jun 7, 2016 :
    Yes me too had same the issue double tap not working and also music control gesture not working
    Acuttuly all gestures option not working except Toggle flashlight its working fine
  3. wallflowerface
    Eclair Jun 7, 2016
    Ah okay, I just read on another post that the gestures is a common problem. So I guess we wait for a fix for now?
  4. vincent90
    Jelly Bean Jun 7, 2016
    vincent90 , Jun 7, 2016 :
    For me everything is ok. Have you done a clean installation? Or a reset after the update?
  5. leovee
    Cupcake Jun 9, 2016
    leovee , Jun 9, 2016 :
    If I turn the option off and then back on again (under gestures) it works for a few hours.
    I am presuming that this conflicts with some other setting that is taking precedence.
    However, as I have gotten used to waking the phone in this manner, it is a huge inconvenience.
    daltocs likes this.
  6. Massudo88
    Eclair Jun 9, 2016
  7. Playboy
    Froyo Jun 9, 2016
    Playboy , Jun 9, 2016 :
    Same here after the update last night........always SOMETHING! after an update......arghhhhhhh!!!
  8. RafaelDeJongh
    Cupcake Jun 10, 2016
    RafaelDeJongh , Jun 10, 2016 :
    I have the exact same problem and it's one of the features I use the most to unlock my phone! Really annoyed by this, for me the double tap only works after rebooting and then it only works the first time, after closing my one plus cover it doesn't function anymore!
    I wonder if this has to do something with the light sensor!
    bigred065 likes this.
  9. JGP@Shanghai
    Cupcake Jun 12, 2016
    JGP@Shanghai , Jun 12, 2016 :
    same problem here and i was glad the update solved a couple of issues (ie unlocking camera but camera doesn't come on and a MUCH better fingerprint scanner...can do sideways scan now)......but this (2TAP-UNLOCK) is a BIG ISSUE. 99% of the time i just double tap to unlock and now i can't....ONEPLUS, please release a FIX A.S.A.P. i just recommended the OP2 to my younger brother yesterday and i think i will retract it. unhappy customer!
  10. ratification
    Ice Cream Sandwich Jun 12, 2016
    ratification , Jun 12, 2016 :
    After update, double tap to awake didn't work for me, all other were working, sleep, skip, etc. i turned gestures off and on, it started working.
  11. SeanPlus
    SeanPlus , Jun 12, 2016 :
    Same...
    Under Settings > Gestures, unticking and then ticking 'Double tap to wake' gets it working again and it continues to work until I close the [official OnePlus] flipcase.
    m_kozal likes this.
  12. Aj115
    Donut Jun 13, 2016
    Aj115 , Jun 13, 2016 :
    Double tap to wake is working for me but when i double tap to lock ( using action launcher) i cant unlock with fp, only the pin code unlocks it then.
  13. Elresidente
    Cupcake Jun 13, 2016
  14. paulomah
    Froyo Jun 14, 2016
    paulomah , Jun 14, 2016 :
    Same issue for me, works after un-ticking and re-ticking for a while then stops altogether
  15. JustAPhone
    Ice Cream Sandwich Jun 14, 2016
    JustAPhone , Jun 14, 2016 :
    Oh... i thought my phone is something wrong with it... so is happening to most people.. this only happen after i clean flash to 3.0.2
    need to turn the gesture on and off again or reboot.. to make it work again.
  16. bornadujmic5
    Cupcake Jun 14, 2016
  17. Deactivated User
    Jun 16, 2016
  18. dameybee
    Cupcake Jun 17, 2016
    dameybee , Jun 17, 2016 :
    Same for me. My OP2 lost constant "double tap to wake" feature after update! New A fix!
  19. svenlaurens
    Cupcake Jun 20, 2016
    svenlaurens , Jun 20, 2016 :
    Same here, I found that restarting the phone will enable it again for a while. Haven't found the cause to why it stops (after unlocking/locking, being in the pocket while buttons are pushed, something else?)...
  20. sandeep chowdary888
    Cupcake Jun 21, 2016
