Display Double tap to activate gets deactivated
  1. tonijuve Cupcake Nov 7, 2018
    tonijuve, Nov 7, 2018 :
    Hi all!
    I have a problem, although I set double tap to activate, it stays on some hours and then it does not work anymore.
    So, I go to settings and find it deactivated....
    Any reason why it self deactivates?
    I like it on because I double tap and it detects my face and unlocks...
    Very strange that it turns off by itself.
    Thanks
    Toni
  2. Ram6T Cupcake Nov 7, 2018
  3. tonijuve Cupcake Nov 7, 2018
  4. DannyTraan Donut Nov 8, 2018
    DannyTraan, Nov 8, 2018 :
    Does this happen often? Because the settings allows you to either take the phone up with one tap or with two taps. You can't turn both on.
    bbfh likes this.
  5. lazytaroice Cupcake Nov 8, 2018
    lazytaroice, Nov 8, 2018 :
    so i know double tap to wake gets turned off if you have any other tap features from sleep on. like Ambient display > tap the screen to show.
    I have another issue where double tap to wake is ON, just never works.. :(
    Leonlu likes this.
  6. Vamsi Saladi Gingerbread Nov 8, 2018
    Vamsi Saladi, Nov 8, 2018 :
    Either Single tap in Ambient display or Doubletap in gestures can be enabled at a time.
    But even when I am using single tap wake up, Phone doesn't respond 50% of the time.
  7. tonijuve Cupcake Nov 8, 2018
    tonijuve, Nov 8, 2018 :
    Hi!
    OK, thank you. I will make sure that only one is enabled and will let you know.
    Thank you so much guys :)
    So, I can put on "reise to wake" but NOT "tap to wake". And then I can have double tap to unlock.
    Is this correct?
    Toni
  8. lazytaroice Cupcake Nov 8, 2018
    that's what i have it as, but raising the phone to wake doesn't always register for me, gotta shake it a little. lol. maybe i should send the phone back...
    note: during ambient display there's a fingerprint icon, but it doesn't work for me. Let me know if it does for you :eek:
  9. tonijuve Cupcake Nov 8, 2018
    Hi!
    I have no issues at all with exception of the one in subject.
    It may be that your unit is faulty or just need a fresh install.
    And by the way, now that tap to wake is off, I have no issues at all, so this case is solved :)
    Kind regards
    Toni
  10. lazytaroice Cupcake Nov 9, 2018
    lazytaroice, Nov 9, 2018 :
    after turning it on today (it's not my daily driver atm) all the features seemed to work! some voodoo stuff going on
  11. F_Jeff_Mitchell_IWcT Cupcake Jan 5, 2019
    F_Jeff_Mitchell_IWcT, Jan 5, 2019 :
    It puts up a fast warning box that it is turning off a feature when you go in to turn on single tap Ambient or double tap wake. Warning really disappears too fast to read it.
    I see no reason why a single tap gesture and a double tap feature can't exist at the same time. There are Android gestures out there that allow using a double tap and a single tap simultaneously
    I hope they change this. I'm very annoyed.
