2
Double tap to wake always vibrates
  1. mrek
    Donut Jun 10, 2018
    mrek , Jun 10, 2018 :
    Hello,
    I recently discovered on my OnePlus 6 that the amazing double tap to wake feature always vibrates. I turned off the vibrations in settings, tried the alert slider on Silent mode, but the vibrations are still happening. The vibrations are really annoying, does anyone have an idea how to turn them off?
    Thank you, Marek
    bojler and Deactivated User like this.
  2. AmanSingh1996
    Eclair Jun 10, 2018
  3. mrek
    Donut Jun 10, 2018
    Unfortunately, that does not solve the problem.
    vwite likes this.
  4. outpin
    Honeycomb Jun 10, 2018
    outpin , Jun 10, 2018 :
    I remember there was a option to turn off gesture vibration. Just search the settings.
  5. mrek
    Donut Jun 10, 2018
    Vibrate on tap feature is turned off. I didn't find any other option (except the vibrator intesity, which is set to minimum - light option).
  6. vwite
    vwite , Jun 10, 2018 :
    There is no option to turn the vibration when double tap to wake. It also bothers me I found people have been complaining in this forums since the OnePlus 3 or 5 but Oneplus team don't do anything and when people complain fanboys just shut them off telling to settle with lowest vibration setting. I suggest you submit a ticket to OnePlus. Won't solve the problem for now but maybe in the future if the actual customer service keeps gettings compalins.
    However, if you rooted I think you can use "VibraFix":
    https://forums.oneplus.com/threads/...n-for-wake-up-the-phone.778630/#post-18586383
    mrek likes this.
  7. mrek
    Donut Jun 10, 2018
    Thank you, I will definitely submit a ticket.
    VibraFix looks reasonable, but I am not planning to root the device soon.
    vwite likes this.
  8. ChenAlain19
    Cupcake Jul 23, 2018
    ChenAlain19 , Jul 23, 2018 :
    Hey guys ! is there any solution for this problems ( dont want to root my devices eithers )
  9. y2k1ltd
    Gingerbread Jul 24, 2018
    y2k1ltd , Jul 24, 2018 :
    There no solution, I've asked support and they told me there no way to disable it but they will send it over to the Dev team to consider in future updates .
  10. parham.brz
    Cupcake Nov 24, 2018
  11. mrek
    Donut Nov 24, 2018
  12. O1571998238793
    Cupcake Nov 8, 2019
    O1571998238793 , Nov 8, 2019 :
    Hi All,
    I am facing this problem after upgrading to Android 10. Double tap to wake vibrates even if the touch vibration is turned off. This is very annoying . Any help will be greatly appreciated.
    S1559903173085 likes this.
  13. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Nov 8, 2019
    Artemus , Nov 8, 2019 :
    Couldn't have posted this in the update thread?
    Caoimhín likes this.
  14. pridhiviraj thiruvengadam
    Cupcake Jan 4, 2020
  15. priiitttt
    Cupcake Apr 19, 2020
  16. sfksuperman
    Honeycomb Oct 29, 2020
    sfksuperman , Oct 29, 2020 :
    I'm using op6t with stock 10 and none of the options suggested till now works! It still vibrates on dt2w. Even this vibrafix app is long dead and not working. Any real workaround please?
  17. LucasOP6
    Cupcake Dec 5, 2020
    LucasOP6 , Dec 5, 2020 :
    I had the same problem with vibration, also with hiding notch and notification light for missing calls. Looks like Android 10 doesn't work well on OP6. This is why I downgrade to Android 9. The only downside of Android 9 is that dark mode doesn't make navigation bar at the bottom black.
    OP6 user.
