Double tap to wake doesn't work most of the times
  1. BurhanV
    Eclair Nov 16, 2019
    BurhanV , Nov 16, 2019 :
    Software bug.
    Double tap does not work most of the times and have to use power button to unlock.
    All latest updates perfomed, but issue persist.
    A1572130375879 likes this.
  2. BurhanV
    Eclair Nov 16, 2019
    I also want to top up on this, when you turn the Double tap in ambient display option it does not work.
    Then under gesture if you enable that it works but somehow automatically it gets turn off in Ambient Display section.
    Seems to be conflicting with each other.
    This really needs a fix because using the power button all time is really frustrating.
  3. T1572614580348
    Cupcake Nov 16, 2019
    T1572614580348 , Nov 16, 2019 :
    I had the same problem. This morning I finally received Oxygen OS 1.0.0.6 and I didn't have any problems since now.
    Which Version are you running on?
  4. kKoI1233
    Froyo Nov 17, 2019
  5. voltaire9
    Froyo Nov 17, 2019
    voltaire9 , Nov 17, 2019 :
    Ha! Just put it in your pocket and walk around for a few feet, it will open up in your pocket. I'm having the problem with 7T waking up in my pocket with double tap enabled, extremely sensitive screen.
  6. A1572130375879
    Cupcake Nov 17, 2019
  7. BurhanV
    Eclair Nov 17, 2019
    BurhanV , Nov 17, 2019 :
    I am using the latest version I believe.
    Check this.
    The issue is not yet resolved, or I think have to wait for the new update.
  8. BurhanV
    Eclair Nov 17, 2019
    There are other software bugs also I have nothiced, but this is not the right thread to put on.
    I'll update on other thread once I finish experimenting on it.
  9. kvnreddy
    Froyo Nov 17, 2019
    kvnreddy , via OnePlus 7T , Nov 17, 2019 :
    after resent update it's working fine..if not working pls reset ur phone after taking backup ..it works fine..becose for me it's working fine
  10. BurhanV
    Eclair Nov 20, 2019
    BurhanV , Nov 20, 2019 :
    Yes, I did the latest update and everything seems to ve working fine now.
