3
Double Tap to Wake - OnePlus 6
  1. Kadesy
    Cupcake Jun 28, 2018
    Kadesy , Jun 28, 2018 :
    Is anyone else experiencing issues with the double tap to wake screen-off gesture not working consistently after a period of idle time?
    When I double tap when the screen has been off for some time, the phone will not wake as expected. Often it will take me a few more tries before it recognises the taps. I have the 256gb model. Have experienced the same issue with pocket mode off and on.
    Is this a known issue I'm unaware of? It's not a massive issue for me, but would love to hear others' thoughts and experiences with their 6.
  2. Beeu
    Beeu , Jun 28, 2018 :
    I also have the same issue with you but it doesn't bother me so much .Sometimes i just failed and straight used the button to wake.
  3. D1529865934326
    Froyo Jun 28, 2018
    D1529865934326 , Jun 28, 2018 :
    Yes I am facing the same issue. Double tap to lock works only at the center of the screen sometimes. And after not using the phone for a couple of minutes double tap to wake doesnt work as quick as it should be. Fingerprint reader also doesn't recognize that quick if we don't use the phone for a longer time.
    Oneplus should come up with an update ASAP solving battery problem and these small glitches hopefully!
  4. Kadesy
    Cool, just wanted to know if it was just me. I'm sure if it's a software issue then it will be resolved in due time. Thanks for the responses.
  5. E1527438888728
    E1527438888728 , Jun 28, 2018 :
    yes it happens with my phone too. everything else is fine though!!
    Also there is some battery backup time reduced after latest update.
