Double tap to wake screen Not working
  1. Mohammed_omer
    Cupcake May 30, 2018
    Mohammed_omer , May 30, 2018 :
    After the new oxygenOS 5.1.2 update which clearly mentioned that we will have Double tap to wake screen feature in the home screen settings , but i think they failed to apply that , it is not working on my oneplus 5
    joniahei likes this.
  2. Waveform Modifier
    Marshmallow May 30, 2018
    Waveform Modifier , May 30, 2018 :
    Works for me.
  3. Mohammed_omer
  4. Waveform Modifier
  5. Mohammed_omer
    I dont know after the update i opened the home screen settings and enabled the setting , double tap to lock works fine , but double tap to wake screen feature is not working
  6. Waveform Modifier
    Try wipe cache from recovery
    Mohammed_omer likes this.
  7. ashish140193
    ashish140193 , May 30, 2018 :
    hi,
    double tap to wake up acreen settings is in
    settings>gestures
    try to enable that it should work fine.
    5.1.2 only says about double tap to lock.
  8. Wasim004
  9. Jayvin Kelaiya
  10. kvskv.bharadwaj
    Donut May 30, 2018
    kvskv.bharadwaj , May 30, 2018 :
    Tap and hold the home screen, goto home settings there you'll find double tap to lock. Just turn it on.
    Jayvin Kelaiya likes this.
  11. F_Ronni_Sinti_Sambleben_
    Donut May 30, 2018
  12. Waveform Modifier
  13. Wasim004
    Wasim004 , May 30, 2018 :
    i am jst aslng..nt hijackng
  14. Waveform Modifier
    What you ask isn't related to what the OP is asking. That is hijacking.
