9
double tap to wake up not working in oneplus 7 pro
  1. SAPTARSI 007
    Cupcake May 25, 2019
    SAPTARSI 007 , May 25, 2019 :
    since last 2 days my double tap to wake up not working.
    after the update it was working fine but suddenly before 2days it stopped working.
    please resolve the issue as soon as possible.
    if any other user have same issue then let me know.
    if anybody knows how to fix it then please let me know.
  2. Amit_Dutta
    xHellblazer likes this.
  3. F_Tony_Garcia_Hernandez_
  4. Rocyano
    Rocyano , May 25, 2019 :
    It does not work for me either. I would be grateful for a solution. Otherwise, I have to send the device back.
  5. Steven_Petrillo
    Gingerbread May 25, 2019
  6. Mavalos415
    Donut May 25, 2019
  7. Rocyano
  8. raiderep
    Donut May 25, 2019
    raiderep , May 25, 2019 :
    If you are in a dark or dimly lit room try shining a light on the screen and see if that gets it to work.
    rafab21 and B1559357308726 like this.
  9. xHellblazer
  10. Trevor_Neu
    Cupcake May 26, 2019
  11. U1557910875481
  12. Rocyano
  13. Abymisra
    Abymisra , May 26, 2019 :
    Ambient display and double tap to wake was not working for me as well from yesterday. Today got an update, was working fine for sometime. Now, again, it's not working
  14. bobslavina
    bobslavina , May 26, 2019 :
    [QUOTE = "Abymisra, post: 20334488, membro: 2069774"] La visualizzazione ambiente e il doppio tocco per svegliare non funzionava anche per me da ieri. Oggi ha ottenuto un aggiornamento, stava funzionando bene per qualche tempo. Ora, ancora, non funziona [/ QUOTE]
    If you have fingerprint unlocking, it doesn't work
  15. Abymisra
    then what's the purpose of fingerprint unlocking?
  16. jeromesola83
    jeromesola83 , May 26, 2019 :
    Hello, pour moi aussi cane fonctionne pas. Jeteint le téléphone et ça refonctionne pendant un certain temps et ensuite ne fonctionne plus. Une mise a jour serait bien car c'est vraiment très embêtant.
    Édit: je viens de m'apercevoir que cela est dû a l'éclairage de la pièce. Dans le noir ça ne marche pas et avec de la lumière ça fonctionne
  17. Nello87
    Cupcake May 27, 2019
    Nello87 , May 27, 2019 :
    Ciao, ho il problema sulla riattivazione dello schermo con il doppio tocco ..... come posso risolvere il problema?
    Non funziona la funzione display ambiente!
  18. Lorenzoem87
    Cupcake May 28, 2019
    Lorenzoem87 , May 28, 2019 :
    my double tap to wake stopped working randomly this morning. reboot, toggle settings, nothing worked. triggered "hey google" to make a command to turn on some lights. now the double tap to wake is working. idk how that could change anything but im guessing it has to do with some battery optimization
  19. JasCola
    Eclair May 28, 2019
    JasCola , May 28, 2019 :
    it's inconsistent for me at times, but I've never had to disable/re-enable to get it back working again, it does on its own.
  20. Queenmallory
    Donut May 28, 2019
    Queenmallory , May 28, 2019 :
    Hello,
    Same issue for me, the functions "Pick up your phone to show" and "Tape the screen to show" no longer appear the mode: Ambiant Display and I am forced to press the power button. Disabling and re-enabling it does not change anything, including Google Assistant: OK Google. I will test other things and make you a return. Maybe an application that blocks.
    Queenmallory
