12
double tap to wake up or lift to wake up not working
  1. Navjot nanuan
    Cupcake Sep 29, 2019
    Navjot nanuan , Sep 29, 2019 :
    I just got 7t recently in first 10 seconds lift to wake up works even gestures for eg (0 for torch)
    after some time phone goes into sleep mode and nothing works
    only power button works
  2. G_Mudassir_Ahmed_QfpJ
    Donut Sep 29, 2019
  3. K_Kuldeep_Singh_yKcx
    Donut Sep 29, 2019
    Jasdeep Singh Jolly likes this.
  4. karthik oneplus
    Ice Cream Sandwich Sep 30, 2019
  5. swagath37
    Cupcake Sep 30, 2019
  6. Jgandhig
    Jgandhig , Sep 30, 2019 :
    yes correct, lift to wake up not working and ambient display shows icon light with shadow
  7. Akkifmx
    Cupcake Oct 1, 2019
  8. Jasdeep Singh Jolly
    Cupcake Oct 11, 2019
  9. #9
  10. Vaibhav_Kothekar
    Eclair Oct 12, 2019
  11. gnan10
    Froyo Oct 12, 2019
    gnan10 , via OnePlus 7T , Oct 12, 2019 :
    proximity sensor doesn't have to do anything with raise to wake.
  12. karthik oneplus
    Ice Cream Sandwich Oct 12, 2019
  13. gnan10
    Froyo Oct 12, 2019
    karthik oneplus
    I am talking about pocket mode not lift to wake.​
    this thread is about raise to wake and double tap to wake.
    should we assume that you are talking about pocket mode?
    edit: proximity sensor does exists BTW. behind the display. just put some camera on it. you can notice the sensor blinking
  14. karthik oneplus
    karthik oneplus , via OnePlus 3T , Oct 12, 2019 :
    There is nothing to assume. You can again read what I have asked. I have clearly asked about proximity sensor.
  15. gnan10
    Froyo Oct 12, 2019
    eventually you are confused!
    proximity sensor and pocket mode aren't same. :D
  16. karthik oneplus
    Looks like you are new with oneplus. Pocket mode is the name oneplus uses. Which means when you keep the phone in the pocket with the help of proximity sensor phone goes to sleep to avoid accidental button presses. Hope it helps. And it's waste to create a new thread on this that's why I have posted here. Thank you.
  17. gnan10
    Froyo Oct 12, 2019
    Dear Genius
    Nope, neither proximity sensor nor pocket mode are exclusive to OnePlus. and unsurprisingly I'm not new to the OnePlus.
    pocket mode does it's work by taking proximity sensor's help along with ambient light sensor.
    that doesn't mean proximity sensor's sole purpose is to serve pocket mode.
    you are completely off track from the main point.
    this discussion was started from the feature raise to wake. which is completely independent and different from pocket mode.
    hence it doesn't have to use proximity sensor or ambient light sensors. instead it depends on Gyroscope and magnetometer.
    Half knowledge is dangerous.
    Have a great day.
  18. lalitbhardwaj72
    Cupcake Oct 29, 2019
    lalitbhardwaj72 , Oct 29, 2019 :
    mine is working before i got update . after update its not working all screen features likhe draw to launch camera and other. tap to wake up screen double tap to wake up are not working. its fault in ambient display i think because its in sleep mode only lock button will help you.
  19. P1572543261522
    Cupcake Oct 31, 2019
    P1572543261522 , Oct 31, 2019 :
    I justgot 7t recently in first 10 seconds lift to wake up works even gestures for eg (0 for torch)
    only power buttonw
    FrankvandeBunt likes this.
  20. V1575404543278
    Cupcake Dec 3, 2019
    V1575404543278 , via OnePlus 7T , Dec 3, 2019 :
    same issue with me. Got my one plus 7t today. After update ambient display is not working. On other hand under same lightining conditions one plus 6t is working exceptionally well. Please help should I get my phone replaced???
