3
Double tap to wake up screen isn't working properly
  1. supun_TD
    Cupcake Jul 4, 2020
    supun_TD , Jul 4, 2020 :
    On my one plus 7 double tap to wake up the screen feature is not working properly after last update.it's been like 2 months and no solution to be found.i think lot of OP 7 users are facing the same issue.hope one plus will fix this issue from new update.
  2. Artemus.
    Nougat Jul 4, 2020
    Artemus. , Jul 4, 2020 :
    You know, this exact problem would've came up if you had searched beforehand.
    rHITkM and DMaarten like this.
  3. S1591808008348
    Cupcake Jul 5, 2020
  4. Bakgrund
    Froyo Jul 5, 2020
    Bakgrund , Jul 5, 2020 :
    It's the same for everyone and Oneplus has not even acknowledged the issue so anyone saying it will be fixed for the next update is just guessing. All you can do is pray that it will be fixed, but don't count on it.
    supun_TD likes this.
  5. Artemus.
    Nougat Jul 5, 2020
    Artemus. , Jul 5, 2020 :
    They did acknowledge it.
  6. S1591808008348
    Cupcake Aug 4, 2020 at 5:03 AM
  7. Artemus.
    Nougat Aug 4, 2020 at 5:06 AM
  8. S1591808008348
    Cupcake Aug 4, 2020 at 5:08 AM
  9. S1591808008348
    Cupcake Aug 4, 2020 at 5:10 AM
  10. Anmol_46
    Froyo Aug 4, 2020 at 5:26 AM
    Anmol_46 , via OnePlus 7 , Aug 4, 2020 at 5:26 AM :
    Its a software issue which I hope would be fixed in the upcoming built.
  11. cameronbach
    Donut Aug 4, 2020 at 9:00 AM
