18
Double Tap To Wake up screen issue via OnePlus 7
  1. D1575687852802
    Cupcake Jun 4, 2020
    D1575687852802 , via OnePlus 7 , Jun 4, 2020 :
    Team,
    After I upgraded to 10.3.3, I facing some issue with double tap to wake up screen. This option is not working when I keep my mobile standby for some time. I have to press power button to wakeup the screen unless double tap.
    Can some one adress me on this. Thanks in advance.
  2. Augfernandes
    Donut Jun 4, 2020
    Augfernandes , Jun 4, 2020 :
    Am also facing the same issue after 10.3.3 most of the time it won't turn on the screen ive to trigger the power button does any has a fix or it's a os issue??
    OnePlus please respond
  3. HijodeRex
    Cupcake Jun 4, 2020
    HijodeRex , Jun 4, 2020 :
    hello, I just wanted to add that I'm facing the same issue, my op7 is brand new and I'm often getting no response to wake up after I press the screen or try to make gestures like the flashlight, for example.
    I installed an anti-spy screen on it, but I don't think that could be the problem?
  4. Artemus.
    Nougat Jun 4, 2020
    Artemus. , Jun 4, 2020 :
    Is the screen tinted? That could be the problem.
  5. HijodeRex
    Cupcake Jun 4, 2020
    it's one of those that don't let people see from sideways, don't know if that counts as tinted 🤷
  6. Artemus.
    Nougat Jun 4, 2020
    I mean, technically it does? The screen tints at an angle which is how it counts as a "privacy screen" which could affect gestures.
    HijodeRex likes this.
  7. ak0002
    Cupcake Jun 5, 2020
  8. Fahim.atul
    Donut Jun 5, 2020
    Fahim.atul , Jun 5, 2020 :
    Having the same issue after 10.3.3 update. Is there any fix?
    Device One plus 7
    I1559639562846 likes this.
  9. A1572053200111
    Cupcake Jun 6, 2020
  10. Paulo Viana
    Gingerbread Jun 6, 2020
  11. fasals
    Cupcake Jun 8, 2020
  12. Mr. Smith
    Cupcake Jun 8, 2020
    Mr. Smith , Jun 8, 2020 :
    The launcher app settings must be reset. This will fix the problem, but the home page data and settings will be lost!
    Settings > Apps > Oneplus Launcher > Clear data & clear cache
  13. adrianral
    Cupcake Jun 15, 2020
    adrianral , Jun 15, 2020 :
    I'm facing the same kind of issue since yesterday . Thought after updating it will be fine, just half n hr back updated to Oxigen OS 10.3.3.GM21AA and still the issue remains the same ...
  14. E1577720277054
    E1577720277054 , Jun 15, 2020 :
    same here...I am also facing the same issue...Thr screen dont wake even if we tap numerous times...please resolve this issue in the next update... thank you
  15. ssuthar91
    Donut Jun 15, 2020
    ssuthar91 , Jun 15, 2020 :
    Am also facing the same issue after 10.3.3 most of the time it won't turn on the screen.
  16. V1592214716386
  17. O1583490040652
  18. sahilpcs
    Froyo Jun 16, 2020
    sahilpcs , via OnePlus 7 , Jun 16, 2020 :
    I am also facing the same issue after this update. please try to get it fixed as soon as possible use this feature so frequently.
    also there is no cross button on other notification panel, but when I touch it's there, just not visible.
  19. jagan_srinivas
    Cupcake Jun 17, 2020
  20. O1583490040652
    Cupcake Jun 19, 2020
    O1583490040652 , Jun 19, 2020 :
    How did you downgrade can you give me the steps thanks
