Double Tap to wake via OnePlus 7T Frosted Silver
  1. #1
  2. ghostofcain
    Marshmallow Mar 23, 2021
    ghostofcain , Mar 23, 2021 :
    And why have you not raised this in the existing release thread? That's where the cool kids discuss issues with new builds, and keep the forums clean and tidy. Obviously you are not one of the cool kids.
    BTW it works fine for me.
    Donald Nice, Aaron2017 and Tokolozi like this.
  3. Tokolozi
    Most Original Avatar Mar 23, 2021
    Tokolozi , Mar 23, 2021 :
    Dumb question, has he tried turning the option off and on again?
    Aaron2017 and ghostofcain like this.
  4. #4
  5. GaganPlus , via OnePlus 7T Frosted Silver , Mar 23, 2021 :
    Idk I don't use this app much. Will post in that thread. Thanks.
    ghostofcain likes this.
  6. corpierro
    Donut May 5, 2021
    corpierro , via OnePlus 7T , May 5, 2021 :
    I have the same issue but noticed that's only occurs in low light conditions. Wiping cache solves problem only for a short while. I discovered a strange phenomina, if you cover the top edge of the screen (selfie camera) and release again the problem is gone for a while. Problem with light/proximity sensors should be the problem, also lot of fingerprints on that location of the display?
    Sam197 likes this.
  7. pa1.
    Honeycomb May 5, 2021
    pa1. , via OnePlus 7T , May 5, 2021 :
    There are many issue with the Android 11, if you aren't happy with day to day stability of A11 , better to revert to A10.
  8. Bhaveshgajwani
    Cupcake May 13, 2021 at 5:44 PM
