5
Double tap wake up
  1. vysakhcbg
    Donut Nov 18, 2018
  2. Lucar1o
    Cupcake Nov 18, 2018
    Shashwat_Mehta likes this.
  3. Neburnil
    Donut Nov 18, 2018
    Neburnil , Nov 18, 2018 :
    I have a similar problem, sometimes when i double tap, the phone do not wake up. I think it is the same problem that the 5t has, which is the optimisation that cut the double tap process but I hope they will solve it
  4. vysakhcbg
    Donut Nov 19, 2018
    vysakhcbg , Nov 19, 2018 :
    yes I have it , but it's came with phone it's self from One plus , it's very thin protector.
  5. vysakhcbg
    Donut Nov 19, 2018
    yha , I hope so , we will wait [e]1f60a[/e]
  6. A1541134380649
    Eclair Nov 20, 2018
    A1541134380649 , Nov 20, 2018 :
    Sometimes when I double tap, it does not even respond. Then I press power button and screen wakes up after few seconds.
    I have fp scanner and face unlock on.
    this happens once per day.
  7. stepansonsky
    Eclair Nov 20, 2018
    stepansonsky , Nov 20, 2018 :
    For me double tap to wake is sometimes working, sometimes not even if I'm trying it for a couple of times. It seems like a bug.
  8. moonspeak
    Froyo Nov 21, 2018
    moonspeak , Nov 21, 2018 :
    Same here. It's much less responsive than it was on the 5T. The 6T seems that it doesn't react if you tap too quickly. The 5T, you could double tap very rapidly and it would still turn on, but with the 6T, it seems you have to be a tiny bit slower, but still it sometimes doesn't turn on.
  9. mercurymod
    Gingerbread Nov 25, 2018
    mercurymod , Nov 25, 2018 :
    if you have tap to wake ambient display it will shut down double tap to wake, and I think another setting shuts it down as well.
  10. Milen Eddy
    Cupcake Nov 25, 2018
    Milen Eddy , Nov 25, 2018 :
    yes it happens to me too . I am using oneplus 6t ,8+128 and double tap to wake doesn't respond twice or thrice a day .Also, sometimes power button too becomes unresponsive .After sometimes it's all go back to normal. I am on 9.0.5
    A1541134380649 likes this.
  11. laocheebye
    Froyo Nov 25, 2018
    Milen Eddy likes this.
  12. SUJEETHAA@89
    SUJEETHAA@89 , Nov 25, 2018 :
    for me also same problem... double tap wake is not working ...and I use power buttons to wake up..
  13. B1542018692222
    B1542018692222 , Nov 25, 2018 :
    for me the same problem but with one tap option. I am on 6t. I have a screen protector from the start, but even tapping harder doesn't t work.
    It happens once a day and it doesn't matter which part od screen i am tryining to tap. I have to press the power button to get any response.
    I hope that the new version of Oxygen will bring some change.
  14. M1541811667968
    M1541811667968 , Nov 25, 2018 :
    Anch'io riscontro lo stesso , a volte in base forse alla velocità del doppio tocco o forse dal fatto di risvegliare il terminale dopo parecchio inutilizzo doppio tocco e nn si sveglia
    Ora fatto da poche ore l'aggiornamento è sembra più reattivo e soprattutto non fa differenza se cambio la pausa tra un tocco e l'altro
  15. Neburnil
    Donut Nov 26, 2018
    Neburnil , Nov 26, 2018 :
    I update my phone to the lastest version and the double tap wake up respond almost never at the first attempt but only at the second after some time of sleep mode.
    vigneshtom and A1541134380649 like this.
  16. Phillyslix
    Gingerbread Nov 27, 2018
    Phillyslix , Nov 27, 2018 :
    Toggle off double tap to wake. Restart. Then enable double tap to wake. Does it work as expected now?
  17. vigneshtom
    Eclair Dec 3, 2018
    vigneshtom , Dec 3, 2018 :
    op 6 r 6t?.....
  18. Neburnil
    Donut Dec 3, 2018
  19. Jerewie
    Cupcake Dec 3, 2018
    Jerewie , Dec 3, 2018 :
    Personally I don't have this troubles, and I just need one tap on my screen to wake up.
    On OP6T 8/128
  20. vigneshtom
    Eclair Dec 3, 2018
