Double To Lock Feature in OP5T
  1. Z1514170582007
    Cupcake May 31, 2018
  2. ravisindhu
    Donut May 31, 2018
    ravisindhu , May 31, 2018 :
    Update your oneplus launcher from play store then go to launcher setting and turn on Double Tap to Lock.
  3. Ak@oneplus
    Gingerbread May 31, 2018
  4. zaxxan
  5. Wackencorpse
    KitKat May 31, 2018
    Wackencorpse , May 31, 2018 :
    He is talking about double tap to lock and not to wake. You should read the post before answering. ;)
    You'll find the new feature in the (OP) launcher settings.
    Liehjan likes this.
  6. Z1514170582007
    Cupcake Jun 2, 2018
    Z1514170582007 , Jun 2, 2018 :
    it's already updated but it's not showing in settings
  7. Nick 59
    Marshmallow Jun 2, 2018
    Nick 59 , Jun 2, 2018 :
    Launcher settings, not 'system' settings.
    What do you see when you Long-press on homescreen, then select the 'gear' settings icon?
  8. Dinesh karmur
    Cupcake Jun 2, 2018
    Dinesh karmur , Jun 2, 2018 :
    hold touch on home screen nd go to home setting nd click double tap to lock....it done
    still not active ...contact me..9727885086
  9. Z1514170582007
    Cupcake Jun 2, 2018
    not getting it bro
  10. Z1514170582007
    Cupcake Jun 2, 2018
    what launcher settings.. one plus launcher is not showing any settings
  11. Deactivated User
    Jun 2, 2018
  12. Nick 59
    Read my reply again!
    Have long-pressed homescreen? Then select the gear icon to get Launcher settings.
    Let us know what options you then see...
  13. Z1514170582007
    Cupcake Jun 2, 2018
    found it and done it bro thanks for the help
  14. tWoBrO
    Gingerbread Jun 2, 2018
    tWoBrO , Jun 2, 2018 :
    Here:
    If you don't have the option to "Double tap to lock" on your Launcher Settings, you don't have the latest version of it. Update from Playstore or go to apkmirror and download it and try again.
  15. Nick 59
    Glad you finally 'found' it and it is working.
    Solution was given in the very first reply btw. Worth reading and digesting answers more carefully. If you didn't know how to get to launcher settings why not just say so? [e]1f609[/e]
  16. Artemus.
    Nougat Jun 2, 2018
    Artemus. , Jun 2, 2018 :
    Don't post your phone number in public.
  17. G_Usha_Rani_vhRC
    Donut Jun 2, 2018
