18
Downgrade from Android 10 to Android 9
  1. c_harish87
    Eclair Oct 18, 2019
    c_harish87 , via OnePlus 7 , Oct 18, 2019 :
    Hi bro. I rooted my oneplus 7. I want to go back downgrade Android 9 version. Can I do this method downgrade android 9. Because my oneplus 7 bootloader unlock and rooted. So I ask you this question. Please reply bro
    #41
  2. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 18, 2019
    #42
  3. zyrrasdad
    Cupcake Oct 18, 2019
    zyrrasdad , via OnePlus 7 Pro , Oct 18, 2019 :
    I remember back in the good old days when you could just wipe the phone and reinstall the older version.... I have the official release of Android 10 and I don't think I could install the beta version and then go back to Android 9. Or am I missing something?
    #43
  4. Swejuggalo
    Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 18, 2019 :
    A beta can normally be installed over stable if it's newer than stable.
    A beta can be updated to stable if the stable is newer (but it will wipe the phone).
    If you are in a situation where you want something that is older than the current installed version you need a rollback first.
    #44
  5. zyrrasdad
    Cupcake Oct 19, 2019
    zyrrasdad , via OnePlus 7 Pro , Oct 19, 2019 :
    The wanting something older is what I want. I was also looking at the msm package, but it's usually referenced to having a beta installed, which I don't.
    #45
  6. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 19, 2019
    Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 19, 2019 :
    The rollback does not care if it's beta or stable. It will downgrade to 9.
    #46
  7. zyrrasdad
    Cupcake Oct 20, 2019
    zyrrasdad , via OnePlus 7 Pro , Oct 20, 2019 :
    Ok, just to be clear (at least in my head) stable and the official release are one in the same?
    #47
  8. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 20, 2019
    Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 20, 2019 :
    Official is everything released by OnePlus. Stable is 10.0.1 for example and is part of the stable update channel. Betas like open beta 1,2,3 are part of the beta update channel.
    #48
  9. zyrrasdad
    Then I have the official release. So the rollback (msm) won't work?
    #49
  10. Swejuggalo
    The rollback should work regardless. It should allow you to revert from beta or stable to 9, whatever reason you may have to do so. It allows you to change to beta or stable when the change is prohibited due to the newest available OS already is installed.
    Some users have reported issues with rollback though. Of some reason some need to flash it twice before it accepted it without errors.
    It's still just as a ordinary local upgrade. Download, move to local storage, check file name, rename if needed (it needs to be a zip file, not zip.jar or anything else). Flash
    #50
  11. zyrrasdad
    Using the local update function, it doesn't see the file, under the original name or renamed. It is dot zip file. This is rather frustrating to say the least. My two OnePlus 6's will definitely not be upgraded.
    #51
  12. Swejuggalo
    It's located under local storage too?
    Update/Downgrade your phone with starting from the community app. Step by step video. Some awesome entertainment during the download included. Downgrade file exists in the first post in OB1.
    https://forums.oneplus.com/threads/...-for-the-oneplus-7-and-oneplus-7-pro.1099154/
    Video : http://bit.ly/2lPAkuy
    Many users enjoy both 10.0.1 and beta 3...
    #52
  13. zyrrasdad
    Yes, it's in the root level. Where all the local update files are usually located.
    #53
  14. Swejuggalo
    Sure it's really .zip then? You could rename the file by deleting its name completely and writing just "file.zip".
    Maybe I can see what could be wrong if you post a few screenshots
    #54
  15. zyrrasdad
    Cupcake Oct 22, 2019
    zyrrasdad , via OnePlus 7 Pro , Oct 22, 2019 :
    Swejuggalo
    Maybe I can see what could be wrong if you post a few screenshots​
    Yep, it's a zip file. I even moved the same package from my computer and the Android 9 package. It shows the Android 9 package but not the other one. Maybe I'll rename it OnePlus something or another...
    This was frustrating at one point, but now it's getting ridiculous.
    Btw, I did rename the whole file and that didn't work.
    #55
  16. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 22, 2019
    Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 22, 2019 :
    The video file I linked before does not help?
    #56
  17. akauts
    Cupcake Oct 23, 2019
    akauts , Oct 23, 2019 :
    i plan to downgrade my op7, question
    1. i didnt found the link to download android 9 from the web posted on top comment
    2. i am in indonesia, is there any region/file version that i need to make sure before download from that source?
    please help
    #57
  18. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 23, 2019
    #58
    akauts likes this.
  19. stereo007
    Eclair Oct 24, 2019
    stereo007 , via OnePlus 7 , Oct 24, 2019 :
    yes it's possible cause i have downgraded from 10 to 9 because there is no notch support option in android 10
    just open beta 1 thread and there is link to download 9 pie
    #59
  20. zyrrasdad
    Cupcake Oct 26, 2019
    zyrrasdad , via OnePlus 7 Pro , Oct 26, 2019 :
    I have decided for the time being to stay with 10.0, although there's a 10.0.1 out but of course I tried to install it and it failed for some reason...
    Thanks for your help!
    #60
    Swejuggalo likes this.
