4
Download progress notification not visible
  1. anjojoy92 Froyo Nov 4, 2018
    anjojoy92, Nov 4, 2018 :
    For those facing no notification while downloading from Play store.
    Settings - apps and notifications - see all apps - click on 3 dots above - show system - click on android setup app- click storage - clear both cache and storage.
    Again open settings - search for download manager -open app- click on notification - disable all the enabled settings and enable them again.
    Then restart.
    The issue should be fixed by now.
    #41
  2. prabhat775 Eclair Nov 4, 2018
    prabhat775, Nov 4, 2018 :
    anjojoy92
    Then restart.
    The issue should be fixed by now.​
    Thanks for the above steps, I did exactly step by step and restarted the device. After that I faced the download pending issue. The apps were not downloading at all, they remain at download pending status.
    So i cleared the cache and data of Google play Store and boom it worked. Now download progress bar is there.
    So the steps that worked for me was:
    1) Settings-> app & notification->see all apps->3 dot at top & choose show system-> android setup-> clear cache and data
    2) Go back-> scroll down to download manager app-> turn off all the setting and enable it again
    RESTART NOW
    3) Go to app and notification-> select Google play Store-> clear cache and data
    Now start downloading any app.
    #42
    kedar1461, apik, Heitor and 2 others like this.
  3. H1541347854012 Cupcake Nov 5, 2018
    H1541347854012, Nov 5, 2018 :
    This worked for me in op 6T.....thanks buddy!!!
    #43
    prabhat775 likes this.
  4. E1532790380013 Cupcake Nov 5, 2018
    #44
  5. Maverick2.0 Jelly Bean Nov 5, 2018
    Maverick2.0, Nov 5, 2018 :
    It's still here. I can confirm.. I am on 9.0.2 and it shows as low priority notification.
    #45
    B_Wrath likes this.
  6. SanthoshPSK Donut Nov 10, 2018
    SanthoshPSK, Nov 10, 2018 :
    Thanks mate I too faced similar issue with my oneplus 6T and with these steps, progress bar working fine now
    #46
  7. Viraj Gohil Cupcake Nov 14, 2018
    Viraj Gohil, Nov 14, 2018 :
    prabhat775
    anjojoy92
    Then restart.
    RESTART NOW
    Now start downloading any app.​
    Man I was trying to do all sort of things from yesterday, you were the one who solved it in my OP 6T.
    This issue somehow causes big files to pause download after sometime as things get cleared from cache or something that I don't know, but now thanks to you everything is OK. +1 thumbs up.
    #47
  8. anjojoy92 Froyo Nov 14, 2018
    anjojoy92, Nov 14, 2018 :
    Yes..when downloading big updates the download seems to pause during some intervels.. i have reported this bug earlier to OnePlus bug hunters. hope it will be solved in the upcomming updates.
    #48
  9. Heitor Donut Nov 14, 2018
    Heitor, Nov 14, 2018 :
    oh man, u the best.
    I saved the topic
    thankz
    #49
  10. 7negiashish Eclair Nov 14, 2018
    7negiashish, Nov 14, 2018 :
    this worked for me in Beta 6
    #50
  11. inzamrzn918 Donut Nov 14, 2018
    #51
  12. apik Cupcake Nov 14, 2018
    apik, Nov 14, 2018 :
    thank buddy... its works
    #52
  13. kedar1461 Gingerbread Nov 14, 2018
    kedar1461, Nov 14, 2018 :
    Tried doing same as u say . and problem solved thanks
    #53
  14. Vishwa1810 Cupcake Nov 19, 2018
    Vishwa1810, Nov 19, 2018 :
    Tried this, but its not working with my OnePlus 6
    #54
  15. pp2309 Cupcake Nov 25, 2018
    pp2309, Nov 25, 2018 :
    You're a lifesaver! I had done a factory reset two days ago and had been facing this issue (OnePlus 6 OOS 9.0.2) This fixed it. Thanks a lot!
    #55
  16. guardianzpride Froyo Dec 15, 2018
    guardianzpride, Dec 15, 2018 :
    Hi guys.which one is the android setup app? I have Greek language and can't find Pls post screenshot...
    Thank you
    Edit :I found it and now notification works Thx!
    #56
  17. Anil_Hajari Eclair Dec 23, 2018
    Anil_Hajari, Dec 23, 2018 :
    #57
  18. MalavRaval Eclair Dec 23, 2018
    MalavRaval, Dec 23, 2018 :
    Thanks Bro, Been Facing that issue for a long time in Stable Update
    #58
    Anil_Hajari likes this.
  19. ankpachouri Cupcake Jan 6, 2019
    ankpachouri, Jan 6, 2019 :
    same problem here buddy , I did everything factory reset 4-5 times, cleared cache, disabled apps and re-enabling them, reset app preferences but nothing seems to work. Pissed off trying again and again. Dahh
    #59
  20. Darekb81 Honeycomb Jun 12, 2019
    Darekb81, Jun 12, 2019 :
    Go to download manager in apps & notifications settings. Find download manager, choose notifications, click in progress, change behaviour to show silently. It worked for me.
    #60
