downloading is not work via OnePlus 7
  1. #1
  2. Batman360
    Lollipop Jul 4, 2020
    Batman360 , Jul 4, 2020 :
    Playstore issue, clear cache if playstore or else wait for sometime.
    fragargon likes this.
  3. #3
  4. fragargon
    Jelly Bean Jul 4, 2020
    fragargon , Jul 4, 2020 :
    did you try "installing" different app from playstore?
    Batman360 likes this.
  5. G_Ankit_Tripathi_EqyW , via OnePlus 7 , Jul 4, 2020 :
    fragargon
    i have tried so many apps but no one is downloading if you r using beta 15 kindly tell us. in your mobile playstore is working while using mobile data
  6. fragargon
    I'm using an Op8pro. I never had this problem. There is some nice info around
    Do you have set some limitation on you data??
    play-store-not-working-mobile-data
    https://support.google.com/googleplay/answer/7513003?hl=en
  7. #7
  8. fragargon
    sb ??
    I think you looking to the wrong direction. Check that no limitation is set to sim-data - playstore or google service
    Could you download anything from chrome for example?
    Is you google account still active?
  9. #9
