2
Doze making WiFi disconnect
  1. Magnetic Nerd
    Jelly Bean Jun 24, 2016
    Magnetic Nerd , Jun 24, 2016 :
    Anyone else have this? And slow WiFi speed in general? Everytime I wake my phone up I have LTE on and WiFi needs to reconnect sometimes manually,
    psvas1408 and gaz_0001 like this.
  2. Tokolozi
    Marshmallow Jun 24, 2016
    Tokolozi , Jun 24, 2016 :
    Check under WiFi setting if you haven't enabled to keep WiFi on during sleep.
    pa5t1s likes this.
  3. Magnetic Nerd
    Have indeed and it's enabled
  4. Spelt
    Ice Cream Sandwich Jun 24, 2016
    Spelt , Jun 24, 2016 :
    I personally am not having a problem with Wifi dropping during sleep. Have checked my Wifi speed and am getting the full speed of my Internet. My Internet connection is only rated at 15 mbs I am averaging 16.3 mbs so a higher Internet connection might make a difference.
  5. SadButTrue
    SadButTrue , Jun 24, 2016 :
    i'm also facing the same problem, after (some time) 10 minutes wifi stops working (wifi symbol shows connected)...
    same behavior on 2.4 @ 5ghz
    works well after disabling doze with adb shell dumpsys deviceidle disable
    JasonMR and Deactivated User like this.
  6. Morttem
    Ice Cream Sandwich Jun 27, 2016
  7. Graham Robertson
    Jun 27, 2016
    Graham Robertson , Jun 27, 2016 :
    Glad my fix also helps solve this issue..;)
  8. gaz_0001
    Froyo Aug 8, 2016
  9. JasonMR
    Lollipop Aug 8, 2016
    JasonMR , Aug 8, 2016 :
    Minimal, you'll barely notice it
  10. rabilgic
    Cupcake Oct 8, 2016
  11. psvas1408
    Eclair May 5, 2017
    psvas1408 , May 5, 2017 :
    disabled wifi switcher. now my WiFi is not switching between mobile data and wifi connection
