2
Battery/Charging
Drain battery after New update 6t
  1. Najemnik Eclair Aug 14, 2019
    Ak. and ProtocolX like this.
  2. L1547049801594 Eclair Aug 14, 2019
  3. rarog Lollipop Senior Moderator Aug 14, 2019
  4. anujjain007 Honeycomb Aug 14, 2019
  5. Matteo8719 Gingerbread Aug 14, 2019
    Matteo8719, Aug 14, 2019 :
    when did you update?? usually you need to wait 2\3 days after update.. to check if the battery is good or not
  6. Najemnik Eclair Aug 14, 2019
  7. ProtocolX Donut Aug 21, 2019 at 10:38 AM
    ProtocolX, Aug 21, 2019 at 10:38 AM :
    I had this same problem and I noticed it right after the update... after the update I cleared the cache and charged to 100%... but the battery drain still continued... I decided to clear the cache again at around 25% battery... and then I charged again and left it charging at 100% for some time... the battery drain seems to have disappeared now...
  8. Matteo8719 Gingerbread Aug 21, 2019 at 5:18 PM
    Matteo8719, Aug 21, 2019 at 5:18 PM :
    please check your battery setting, and find the processes and apps that heating your battery
  9. ProtocolX Donut Aug 21, 2019 at 5:22 PM
    ProtocolX, Aug 21, 2019 at 5:22 PM :
    Just checked... nothing out of the ordinary that is draining the battery...
