Battery/Charging draining battery & replacement
  1. engahmedzaky
    Eclair Sep 8, 2018
    engahmedzaky , Sep 8, 2018 :
    Recently my OP3 battery draining very high I have to recharge it maybe twice at least daily I don't know that from the latest update or I need to replace the battery.
    If there is any way to measure battery health to know shall I replace it or no?
  2. Sun90
    Starting Point Expert Community Expert Sep 8, 2018
    Best Answer
    Sun90 , Sep 8, 2018 :
    1) please post the battery stats screenshots for better understanding.
    2) install Accubattery app from store to check your phones battery health.
    rkg111 and engahmedzaky like this.
  3. engahmedzaky
    Eclair Sep 8, 2018
    you need battery screenshot at any level of battery or in a low level
  4. Sun90
    It is advisable to take the screenshots when the battery is down to around 10~15% after a full 100% charge and use.
    This gives a fair idea about the apps consuming battery as well as the Awake and screen on time.
    But do not charge in between while taking the screenshot.
    engahmedzaky likes this.
  5. engahmedzaky
    Eclair Sep 8, 2018
  6. G_Joe_Chooi_keWG
    Eclair Sep 13, 2018
    G_Joe_Chooi_keWG , Sep 13, 2018 :
    I have the same issue after latest update. Just plugged out from charging with 100% and lost 6% within 25 mins usage on Whatsapp and news surfing. Not normal, is it?
  7. F_Wouter_Maes_iCei
    Cupcake Sep 15, 2018
    F_Wouter_Maes_iCei , Sep 15, 2018 :
    Same here, my discharge is going like crazy. I also have the problem that my OP 3 doesn't go into sleep mode by itself. It just keeps on flikkering on (witch partially explains the high percentage in battery usage). I hope it gets fixed soon. Anyone else with these symptons
  8. rkg111
    rkg111 , Sep 15, 2018 :
    The app called Accubattery is the only accurate means of measuring battery capacity on Android devices. You need to run it through 3 or 4 charge cycles to allow it to compute the findings accurately. If your battery capacity is below 80%, the battery should be replaced.
    Apple has its own built-in battery health tool for iPhones but they have the same 80% minimum recommendation.
    Batteries lose their capacity over time, especially after a few years of charge cycles.
    A factory reset of your phone may also help with battery drain issues when battery health isn't the cause, but your stored files will be erased.
  9. engahmedzaky
    Eclair Sep 16, 2018
  10. engahmedzaky
    Eclair Sep 16, 2018
    engahmedzaky , Sep 16, 2018 :
    i had already used it and i got battery health about 83%
