Working Draining of battery in 1+ 7pro
  1. O1562401981210
    Cupcake Jul 6, 2019
    O1562401981210 , Jul 6, 2019 :
    My self Shubham using 1+ 7 pro from couple of weeks.
    As per my experience whenever I play Pubg mobile on this device facing a heavy battery drain.
  2. Akhshay Srinivasan
    Nougat Jul 6, 2019
    Akhshay Srinivasan , Jul 6, 2019 :
    That's obvious because of the game's storage use. Have you enabled f'natic mode ?
  3. O1562401981210
    Cupcake Jul 6, 2019
    No, I was playing on gaming mode
  4. Akhshay Srinivasan
    Nougat Jul 6, 2019
    Ok. Save your game > clear storage > reboot the phone > Try playing on f'natic mode and check now.
  5. stark2991_PL
    KitKat Jul 6, 2019
    stark2991_PL , Jul 6, 2019 :
    High battery consumption during playing games is normal. Compare it to driving a car with max speed - it will use more fuel than normally. Do you understand?
  6. ROHINI25
    Eclair Nov 20, 2019
    ROHINI25 , via OnePlus 7 Pro , Nov 20, 2019 :
    but why it drain when you just make calls and lil bot of social media. still getting max 3hr on time
  7. stark2991_PL
    KitKat Nov 20, 2019
    stark2991_PL , Nov 20, 2019 :
    It means that there is something else that drains the battery.
  8. Gav_W86
    Moderator Moderator Nov 20, 2019
    Gav_W86 , Nov 20, 2019 :
    depends on the apps and use. what do the battery use stats in settings say?
