Arul2293 , via OnePlus 9 Pro , Jan 17, 2022 : Dual channel acceleration symbol not showing or please some one tell how to use/enable it
Gamingtime1121 , via OnePlus 9 , Jan 17, 2022 : Go to settings➡️ Wifi and network➡️ Dual channel network acceleration and switch it on.
Arul2293 , via OnePlus 9 Pro , Jan 18, 2022 : Arleady on dual channel network as shown in 2nd picture attached
Gamingtime1121 , via OnePlus 9 , Jan 18, 2022 : Sorry didn't noticed that but can you check supported apps for dual acceleration by clicking on it.
Rajath Kashyap , via OnePlus 9 Pro Stellar Black , Jan 18, 2022 : Hi please find below images for your reference. 1. Have connected to 2 wifi networks 2. It doesn't show that you've connected to 2 devices when you pull down the shelf. 3. You can check in the main notification status bar area. said: said: Hope this helps Thanks
Arul2293 , via OnePlus 9 Pro , Jan 19, 2022 : Not dual WiFi acceleration attached wrong pics. I need dual channel acceleration ( wifi and mobile data ) same time
