Network/Connectivity Dual sim data on 2nd issue when in call
  1. nidelius
    Cupcake Dec 14, 2019
    nidelius , Dec 14, 2019 :
    So this is my setup:
    Sim1 Telenor (1gb data free calls)
    Sim2 Tre (unlimited data no call capabilities,broadband sim)
    Voice sim1
    SMS sim1
    Data sim2
    Dual 4g active and VoLTE active on sim1
    As I receive or start a call on the Telenor sim. The data dies on the sim 2. Which means I have no data when in call. Is this by design or a bug?
  2. Horsault
    Marshmallow Moderator Dec 14, 2019
    Horsault , Dec 14, 2019 :
    You can't have both cards active at the same time.
    For proof, try to have a call on SIM1 and get another one on SIM2. It's impossible, and SIM2 call will immediately go to your voicemail.
  3. Pauls7pro
    Pauls7pro , Dec 14, 2019 :
    If I'm hearing you correct, are you saying if you have 2 sim cards installed you can't have both working? I mean if sim 1 is your main source for telephone service you wouldn't be able to get calls from sim 2 card while using sim1? Because if so I would have to say you're wrong I can get calls coming from sim 2 while using sim1
  4. Horsault
    Well, I'm afraid you're not. o_O
    Dual active SIM is different from dual standby.
  5. Pauls7pro
    Okay, if you would please explain the difference. I'm guessing with dual sim active one can receive calls from both, yes? Thanks
  6. Horsault
    Both can receive calls from both cards.
    But on a dual active phone, you can have conversation from both SIM cards at the same time.
    On a dual standby phone, if there's a call running on one SIM, all calls coming on the other SIM will be redirected on voicemail. SMS from SIM2 will be received when phone is hung.
  7. Pauls7pro
    Cupcake Dec 15, 2019
    Pauls7pro , Dec 15, 2019 :
    Thank you for this... How can one make calls from sim 2 card when one is using 2 sim cards?
