Dual-Sim Speed Question
  1. tytanmcbride
    Ice Cream Sandwich Jul 15, 2016
    tytanmcbride , Jul 15, 2016 :
    I was looking into getting the OnePlus 3, but wanted to know if both SIM cards were 4G LTE or if one was slower than the other. Thanks!
  2. mynamesleon
    Eclair Jul 15, 2016
    mynamesleon , Jul 15, 2016 :
    I've only got the one SIM card currently, but I've used it in both SIM slots and had LTE in both cases.
    (I don't think there's much, if any, difference between the models in different countries, but just in case there is: I'm in the UK)
  3. kaghedo
    Jelly Bean Jul 15, 2016
    kaghedo , Jul 15, 2016 :
    You can only use one sim at a time for your data anyways ;)
  4. tytanmcbride
    Well my plan was to use one sim for voice calling and sms, and then the other for data only as it works out to be cheaper that way.
  5. Tobikage
    Nougat Jul 15, 2016
    Tobikage , Jul 15, 2016 :
    That can be done.
  6. kaghedo
    100% correct :D
    dennysmith likes this.
  7. planetshg
    Eclair Jul 15, 2016
    planetshg , Jul 15, 2016 :
    Yes, LTE works with both SIMs.
    However, only one SIM card can establish a data connection at a time.
    Switching between both takes about five seconds, despite the popup stating "up to a minute".
    It is known, Khaleesi.
  8. F_Sérgio_De_Sousa_iXXN
    Cupcake Jul 16, 2016
  9. kaghedo
    Jelly Bean Jul 16, 2016
    kaghedo , Jul 16, 2016 :
    Yes it will work if you have ROAMING option set up on either sim cards ;)
  10. jorgen
    jorgen , Jul 16, 2016 :
    I am using one sim for calls and sms and another (from another operator) for data only. It works perfectly and with good speed (haven't measured that much but clocked it at 77 mbits/s the other day.
    tytanmcbride likes this.
  11. tytanmcbride
    Ice Cream Sandwich Jul 17, 2016
    tytanmcbride , Jul 17, 2016 :
    Here's a perhaps trickier question. Since I read that the OnePlus 3 just switches SIM's based on whichever one is being used due to only 1 antenna, what would happen if both SIM cards are by the same carrier, but still following what I said before where 1 is for calls and SMS, and the other for data (so same carrier, just different plans). Would that improve things any?
  12. kaghedo
    Jelly Bean Jul 17, 2016
    kaghedo , Jul 17, 2016 :
    Nope....
  13. tytanmcbride
  14. kaghedo
    No harm at all :cool:
  15. F_Valentin_Bacquet_FFVt
    Cupcake Jul 17, 2016
  16. tytanmcbride
    Do you know if you're able to delete an APN setting? Sorry for all of the questions! I plan on using it with Rogers (voice and SMS) and Telus, but I plan on using their flex data plan for tablets, and people are reporting issues where if the APN is on the wrong setting, you can get charged big time, adn the best bet is to delete one of the APN settings.
  17. kaghedo
    I have not tried this meself so can't give you a definite answer but however if you google your question you will find loads of answers ;)
  18. tytanmcbride
    Ice Cream Sandwich Jul 18, 2016
    tytanmcbride , Jul 18, 2016 :
    Thanks! People seem to be saying that what I want to do with the SIMs, combined with what I've read on this thread, should work! I'll give it a test as soon as I can!
