Duo Not Working on Oneplus 7.
  1. rajarshi5991 Cupcake Jun 19, 2019
    rajarshi5991, Jun 19, 2019 :
    Google Duo is not working properly in my Oneplus 7. When I use it, it shows me blank screen and also when I use bluetooth earphones (specially when i use Xiaomi Bluetooth Audio Receiver) the blank screen continues though the other person can see me properly and can hear me properly.
    is there anyone facing the said problem?
  2. Siddhant0305 Cupcake Jun 21, 2019
    rajarshi5991 likes this.
  3. rajarshi5991 Cupcake Jun 21, 2019
    Siddhant0305 likes this.
  4. nblackstock01 Cupcake Jun 21, 2019
    nblackstock01, Jun 21, 2019 :
    While this does work, I'd hope that we can get an update to resolve this! I use Duo quite a bit and it's a minor inconvenience to have to remember to toggle this setting surrounding my Duo video calls.
    If you get an incoming call while you have video enhancer turned on, the caller's vid will be frozen. Even if while on that call I go to settings and turn it off, the video will remain frozen and require you to hang up and place a new call for the video to work properly.
    Again, a minor inconvenience, but a fix that would be MUCH appreciated!
    rajarshi5991 and Siddhant0305 like this.
  5. J1560331479800 Cupcake Jul 14, 2019
    J1560331479800, Jul 14, 2019 :
    I finally got the Google Duo work on my phone.
    Go to setting - App - Google Duo - uninstall updates. Clear apps data and cache.
    Restart phone - open Google Duo and re-signing.
    Video enhancer can be turned on now.
