Dust inside the top rear camera lens (Oneplus 7T Pro)
  1. jaju123
    Gingerbread Nov 25, 2019
    jaju123 , Nov 25, 2019 :
    Hello,
    I've had this phone for less than two weeks. I imported it from China and thus probably don't have any real warranty. I'm noticing that dust is building up inside the top camera lens on the rear of my phone and I've kept it in a case since I got it. I looked this issue up and others have reported the issue with the OP7 pro but not yet for the 7t pro. I'll try to post some pictures later. What can i do about this? Does anyone else have this issue? Should I try to return the phone before this gets any worse? so far it doesn't seem to be affecting camera quality.
  2. VeLLyJaTT
    Honeycomb Nov 27, 2019
    Y.Singh likes this.
  3. jaju123
    Gingerbread Nov 27, 2019
    jaju123 , Nov 27, 2019 :
    Thanks for your feedback. Ive attached a photo of the issue in case anyone else runs into this problem. I'll try to return the phone :(
  4. SubhashNayak
    Honeycomb Nov 28, 2019
    SubhashNayak , Nov 28, 2019 :
    It is better you replace the phone. Once the dust has entered that zone confirms that there's a fault and I'm sure it'll worsen with time which will effect the clarity of the pictures
  5. jaju123
    Gingerbread Dec 6, 2019
    jaju123 , via OnePlus 7T Pro , Dec 6, 2019 :
    Thanks all for your help. I returned the phone and was able to get a refund thanks to eBay. I bought a new one from Amazon and it has no such problem after a week or so.
    VeLLyJaTT likes this.
  6. dnauck
    Cupcake May 19, 2020
  7. Kiwi25
    Cupcake May 22, 2020
