Earpiece problem via OnePlus 8 Pro
  1. F_Akhil_Akki_VUMC , via OnePlus 8 Pro , Jun 29, 2020 :
    Hello I recently purchased one plus 8pro phone via Amazon. I applied an uv glue tempered but unfortunately some of glue it entered to earpiece then onwards the sound of the speaker is different. Its not working like normal. The sound is totally breaking and moreover a burning smell is coming from earpiece. what should I do to resolve the earpiece as new?
  2. Horsault
    Nougat Moderator Jun 29, 2020
    Horsault , Jun 29, 2020 :
    As I read, your problem comes from your gluing your earphone. What is exactly OnePlus responsibility in your putting glue inside your earphone?
  3. F_Akhil_Akki_VUMC , via OnePlus 8 Pro , Jun 29, 2020 :
    what should I do to resolve this problem. please suggest me?
  4. Horsault
    There's little you can do except removing the glue that came inside your phone. But it means disassembling your device, without damaging your loudspeaker, with might be tricky.
    Your best option will be to contact support or go to your nearest OnePlus service center to get paid repair, as no warranty from any manufacturer will ever cover damage resulting from glue put inside a device.
    F_Akhil_Akki_VUMC likes this.
  5. F_Akhil_Akki_VUMC , via OnePlus 8 Pro , Jun 30, 2020 :
    Thank you sooo much for that.[e]2764[/e]️
  6. Karan_Dua
    Cupcake Jul 3, 2020 at 8:53 AM
