2
Earpiece volume
  1. sau100
    Froyo Jul 4, 2018
    sau100 , Jul 4, 2018 :
    Facing drastically low volume on earpiece after updating it recently to beta 29 Oneplus 3t. So Is the same problem persist on stable version too ?
    Sampath_Kumar_ and shiv1g like this.
  2. Sun90
    Starting Point Expert Jul 4, 2018
    Sun90 , Jul 4, 2018 :
    Is it ( the update)from previous beta or stable.
    And why don't you use the corresponding official thread for it.
  3. sau100
    Froyo Jul 4, 2018
    previous beta
  4. pranav_ec
    Eclair Jul 4, 2018
    pranav_ec , Jul 4, 2018 :
    Had the same problem till yesterday. And i thought of giving it a try and i cleaned it with dry toothbrush, and it worked lol! Its as good as new again and the volume has increased drastically. Maybe give it a try.
    Buzias_Alexandru likes this.
  5. Buzias_Alexandru
    Gingerbread Jul 4, 2018
    Buzias_Alexandru , Jul 4, 2018 :
    had the same happen on a nexus 5, and this solution worked for me also. My 3t sounds ok and i'm on OB29 also.
    So give this a try, it just might work.
    pranav_ec likes this.
  6. onkarr
    Gingerbread Oct 7, 2018
    onkarr , Oct 7, 2018 :
    i did the same but no vain
  7. Romank03y
    Donut Oct 7, 2018
    Romank03y , Oct 7, 2018 :
    actually this thing works....i also did on post regarding the same issue....but after reading comments tried cleaning it with dry brush...and it works perfectly
  8. Paschfire
    KitKat Oct 8, 2018
    Paschfire , Oct 8, 2018 :
    No update is going to fix this, call a OnePlus service center and have the earpiece speaker and grill assembly cleaned.
