9
Sound Earspeaker always makes noise
  1. destroyernr1
    Eclair May 23, 2019
    destroyernr1 , May 23, 2019 :
    Even when the Oneplus 7 pro is in standby and you hold the phone to your ear you can hear some noise. It's like the noise of a charger that you sometimes hear.
    Strange...
  2. Schwabl
    Gingerbread May 23, 2019
    Schwabl , May 23, 2019 :
    That's the sound of coil whine since your device is powered on and using energy.
  3. destroyernr1
    Eclair May 23, 2019
    Ok but it's strange don't you think? NEver heard this from an earspeaker before. I have a smartphone repair shop and this is the first time i've noticed this from an earspeaker...
    I1558429336014 likes this.
  4. juliofcc5oneplus
    Cupcake May 23, 2019
    juliofcc5oneplus , May 23, 2019 :
    It happens to me too. What is the solution?? It is anoying. If I replace the phone with a new one is possible to happen again in the new one??
  5. destroyernr1
    Eclair May 23, 2019
    Had to make some phone calls today and the noise is quite disturbing. Especially when you make long phone calls. The squeeky noise is always there...
    TimtiPRO.de and I1558429336014 like this.
  6. I1558429336014
  7. O1556728330711
    Donut May 23, 2019
    O1556728330711 , May 23, 2019 :
    Hello there. In my case there is a strange noise in the ear speaker during a call. Sounds like an interference.
  8. I1558429336014
    Cupcake May 24, 2019
  9. Prodigyx
    Eclair May 24, 2019
  10. binyster
    Donut May 27, 2019
    binyster , May 27, 2019 :
    I can hear that high pitch noise during calls and in standby mode as well. I tried a few things (no SIM card inserted, WiFi, BT, NFC, location services are switched off) but I can still hear it. I also tried to switch on airplane mode but the noise is still there. During calls it makes me a headache after 2 minutes. If they cannot figure out something soon then I have to send this phone back. :(
    My config:
    Model: OnePlus 7 Pro 256GB/8GB nebula blue (GM1913)
    OS: Oxygen OS 9.5.4.GM21BA
    Network: Vodafone Hungary
    O1563288182756 and destroyernr1 like this.
  11. PuCiNhOOO
    Gingerbread May 27, 2019
    PuCiNhOOO , May 27, 2019 :
    Update to 9.5.5
  12. binyster
    Donut May 27, 2019
    From the official announcement:
    "We are starting to push the incremental roll-out of OxygenOS 9.5.4 and 9.5.5, they are essentially the same builds, but due to recent regulations in the EU and as per Google's instructions we have 2 builds now, one specifically for EU region."
  13. PuCiNhOOO
    What do you want to state with this?
  14. binyster
    Donut May 27, 2019
    Sorry Bro, my bad if I was not clear. I try to clarify it:
    - I am within the EU.
    - If I check for updates on the phone it says I have the latest firmware.
    - The latest firmware that can be found on the official support page is the same that I have.
    - According to my understanding OnePlus hopes that 9.5.4 and 9.5.5 are the same build with the same bugfixes and features.
    Maybe I miss something but I cannot see the point upgrading to 9.5.5 if it is the same as they stated.
    Probably 9.5.5 is not available right now for everybody. From the same announcement that I quoted before:
    "This OTA will have a staged rollout, the OTA will be received by a limited number of users today and will have a broader rollout in a few days after making sure there are no critical bugs,"
    If you have any tips I am still open. Thx!
  15. PuCiNhOOO
    Nope.
    For us in EU, 9.5.4 and 9.5.5 are completly different builds.
    That update for us is the 9.5.5.
    You can just use a vpn to get it earlier, or just use "Oxygen Updater" App to get it sooner.
    Believe me, you will love it, specially on camera department ;)
  16. X1559032921175
    Cupcake May 28, 2019
    X1559032921175 , May 28, 2019 :
    I have the same issue. Had mine replaced and waiting for the new one, maybe it´s a problem for all 7 pro. Hope it can be fixed with an update!
  17. binyster
    Donut May 28, 2019
    binyster , May 28, 2019 :
    Thanks for the "Oxygen Updater" tip! It was pretty easy to install the 9.5.5. ;)
    But unfortunately it has not solved the noise issue and I can still can hear that high pitch noise both in standby mode and during calls. :(
  18. Harsh_oneplus7pro
    Donut May 28, 2019
    Harsh_oneplus7pro , May 28, 2019 :
    Looks like everyone is facing this issue, but I can tell you the reason. Other person's voice from speaker is reflecting back through your upper microphone. So to avoid this , change volume from full to one down while talking on a call.
  19. PuCiNhOOO
    Gingerbread May 28, 2019
    PuCiNhOOO , May 28, 2019 :
    How can you say everyone?
    I dont have it...
    But I allways use my earpiece at minimum, I like how my ears are atm, dont need anything to ear better in a few years [e]1f602[/e][e]1f602[/e][e]1f602[/e]
    Will try it latter anyway to see if I get it too
  20. Harsh_oneplus7pro
    Donut May 28, 2019
    Yeah because you keep them at minimum. Most of the people who keep volumes at maximum are facing this issue, so keep it one down
