2
OxygenOS Easiest way to revert to 8.1?
  1. Snippets69
    Eclair Sep 25, 2018
    Snippets69 , Sep 25, 2018 :
    9.0 has made the phone un-useable due to the new Recent Apps change.
    Is there an easy way to revert to 8.1 without bootloader unlock?
    Kerngehirn3 and RasseTheBoy like this.
  2. dsmonteiro
    Community Consultant Staff Member Sep 25, 2018
    dsmonteiro , Sep 25, 2018 :
    Unlocking the bootloader is not even referred in any official instructions. See below:
    Do bear in mind that this will wipe your phone.
  3. Snippets69
    Eclair Sep 25, 2018
  4. P1533616672184
    Froyo Sep 25, 2018
    P1533616672184 , Sep 25, 2018 :
    hey it's easy
    download beta ROM for Android 9 and flash it from local upgrade in settings
    then download 8.1 ROM .. and flash bingo
    RasseTheBoy likes this.
  5. Snippets69
    Eclair Sep 26, 2018
    Snippets69 , Sep 26, 2018 :
    Where to download the Beta Android 9 ROM? I'm currently on 180915. Is that a Beta ROM?
  6. Adityatawade17
    Honeycomb Sep 26, 2018
    Adityatawade17 , Sep 26, 2018 :
    Share your settings Screenshot with OxygenOs Version
  7. Snippets69
    Eclair Sep 26, 2018
    Version is 180915. I was able to rollback to 8.1 from that ROM. Thanks for the tips.
  8. N1535701860729
    Cupcake Sep 26, 2018
  9. saivychawla
    Froyo Sep 29, 2018
    saivychawla , Sep 29, 2018 :
    i have used this roll back firmware from OFFICAL Android P to OREO 8.1 version.
    MISSION ACComplished.
  10. Snippets69
    Eclair Oct 2, 2018
  11. P1533616672184
    Froyo Oct 2, 2018
  12. pcoventry
    Honeycomb Apr 11, 2019
    pcoventry , Apr 11, 2019 :
    Is there any way to do this with the OTA build? I friggin hate the fact 9 messes with hotspot and android auto - I've been trying tonight to get 8.1 back but the phone won't see it - Short of unlocking and sticking pure android on there - is there a way?
    If not ill have to swap it for a 5T which works fine in all areas - such a shame as this phone was £579 and for that I would expect better - OP say they are fixing it but they are too busy rolloing out the crap 7 which no one will want if OOS is as rubbish as it is on the 6T
