Edge Display via OnePlus 7 Pro
  1. Farhankayyath
    Cupcake Apr 24, 2020
    Farhankayyath , via OnePlus 7 Pro , Apr 24, 2020 :
    I am wondering if oneplus has any specific edge display service like the Samsung Galaxy series has.
    if not, then are they planning to develop something like that?
    I being an ex-samsung flagship series user, really find that convenient and user friendly. and since the OnePlus Pro series already had the curved edge display, it would be amazing to have that feature on the OnePlus aswell!
    anyone else who agrees to this?
  2. nitramcek
    Ice Cream Sandwich Apr 24, 2020
    rockthisfellah and Farhankayyath like this.
  3. Liehjan
    Lollipop Apr 24, 2020
    Liehjan , Apr 24, 2020 :
    As long as stock android doesn't have it, OxygenOS should not have it
  4. Farhankayyath
    yes I get your point, but can't they add some kind of plug in?
    did you use the edge screen feature on s10+?
  5. Liehjan
    Isn't there 3rd party apps on play store you can use?
    Not on the s10+, but I've tried it
  6. Liehjan
  7. Farhankayyath
    yeah brother I tried using them, they are too laggy and uses too much of RAM.
    though I will try the one u sent. I had used some other version from playstore.
  8. Farhankayyath
  9. Liehjan
    No ads if you pay for the app ;)
    Farhankayyath likes this.
  10. Farhankayyath
  11. Secondbushome
    Honeycomb Apr 24, 2020
    Secondbushome , via OnePlus 7 Pro , Apr 24, 2020 :
    That's usually the issue with third-party options. I do also miss the Edge Panel. Switching from One UI to OOS is pretty jarring when you get used to using features like that.
  12. Farhankayyath
