Hello,
OnePlus didn't add 5G to the carrier policy on OnePlus 7 5G , OnePlus 8 Pro and OnePlus 8 .
Here is the way to enable 5G on the phones mentioned above OS 11 – Android 11 :
If your OnePlus 8 pro , OnePlus 8 or Oneplus 7T pro 5G is not connecting to 5G in 5G covered area .
# Use single 5G SIM card in number 1 slot.
Follow the steps here:
Requirements:
1- install EngineerMode apk manually on your Oneplus phone:
http://www.mediafire.com/file/2pr75mgbtq2xv2e/Engineeringmode_V1.01.0.17.apk/file
2- On your computer you need to have OnePlus driver installed:
http://www.mediafire.com/file/zkua1ob0dzaor09/OnePlus_USB_Driver_Setup.exe/file
3- QPST-application. Please find application from internet:
http://www.mediafire.com/file/2nb7d9k4vehvf7m/QPST_2.7.496.zip/file
4- The two XML files with enabled 5G
http://www.mediafire.com/folder/4l2vlenf869pu/5G_Carrier_Policy
5- Qualcomm Drivers .
http://www.mediafire.com/folder/5mzfw32i8dlp5/Qualcomm Drivers
(unzip the files to a folder)
6- USB-cable between your computer and phone.
When you finish and ready:
1- Go to Settings on your Phone – About Phone – Click 8 times on Build number .
2- Go back to Settings – Developer option – Enable USB debugging.
3- On your phone, dial *#801# Use EngineerMode then put Engineer Mode Toggle (ON).
4- Connect your phone to your computer via USB.
5- Go to Control Panel – Device Manager .. you will see two an unknow device.
Right click on the first one – Update Driver – browse my computer drivers - Let me pick form a list of available drivers- click on Have Disk ..- show all devices browse then go to the Qualcomm Drivers that you download earlier. Then do the same to the other unknown Driver. choose 9018 for both unknown drivers.
6- Open then QPST-application. Click on Add new port from the right corner. if it shows 2 add them both.
7- On the menu highlight the port which shows the (Phone Model) Open Start Clients then QPST EFS Explorerand wait until you see the files.
8- Then go to policyman.
9- In the policyman - right list, you will see two files: carrier_policy.xml and carrier_policy.xml_Subscription01. Copy them to your computer as a backup if you need them in the feature.
10 - Now delete the two files (carrier_policy.xml and carrier_policy.xml_Subscription01) files from the policyman - right list.
11- Now go to the tow XML files you already download earlier – 5G enabled network. Copy them to the policymandirectory , drop and drag one each time.
12- Reboot your phone , your 5G is enabled now.
13- Dial *#801# Use EngineerMode then put Engineer Mode Toggle (OFF).
On OnePlus 8 and 8 Pro you may have to enable 5G NR via *#*#4636#*#* then Phone Information -> Set preferred network type. Choose:
NR/LTE/TDSCDMA/CDMA/EvDo/GSM/WCDMA
Or
NR/LTE/TDSCDMA/GSM/WCDMA
Enjoy the 5G speed .
# All the requirements here:
http://www.mediafire.com/folder/25yv56eyrevem/OnePlus_5G_OS_11
Very Big Thanks to:
1- Mr. Minh Truong:
https://mt-tech.fi/en/modify-oneplus-7-pro-5g-8-and-8-pro-nr-lte-a-band-combos/
2- Mr. Abdullah Alshehri :
https://twitter.com/AdAlShehri737
3- Evenshop Themobilestore – YouTube in French:
